Turbo DV8
I have an MH-C808M battery charger. It seems to not fully charge cells under a certain condition. I am in the process of using it to charge eight Powerex 11Ah D-cells prior to discharge/capacity testing. I charged all eight simultaneously, leaving them in the charger upon termination for maintenance charge as I capacity tested each cell one by one. I pick a "done" cell and run it through it's discharge capacity bench test, which yields full rated capacity. Then I reinsert the discharged cell (0.9v - 1.0v) back into it's slot between the other "done" cells for charging. This is where the trouble starts. The charge on the reinserted cell terminates too soon, at about 1.25 volts, instead of the usual 1.45+ volts or so. Instead of taking the usual 12 hours or so to charge on soft charge, it terminates within a few hours, and the second capacity test bears out the fact that the cell has not received a full charge. It has done this twice so far, on separate cells.
What is going on? I am wondering is my unit defective, or is the microprocessor having difficulty dealing with charging a dead cell between other "done" cells on maintenance charge? Maha's Alex told me some time ago that although the manual states to charge from left to right, there is no technical reason why the cells cannot be charged in any order. Please advise. Thanks.
Ron
Ron
