I'm looking for a new mailbox. I'll probably just get the standard rural box, curved top with the red flag on the side. Sort of looks like a quonset(sp) hut. Anyhow I would like to put a light in it.
Here are my specs-
*Light turns on/off with door open/close.
*Runs off small solar panel. See below.
*Operating temperature -40F to 130F (solar heating)
*Low light output
I was thinking a couple LED's maybe powered by a capacitor as I don't know of any battery that would survive the temperature extremes for charging. Though maybe drop the solar panel and use a lithium battery, at a couple minutes use a day it should last a while. Also what color LED would be most efficient?
Color and brightness wouldn't be a factor as it really doesn't need to be bright, just to make sure we don't miss mail. I was thinking of using a magnetic switch so I don't have to worry about moisture/freezing. Also any input on adhesive would be a help. I was thinking of using epoxy or JB weld rather than any screws or rivets so as to maintain weathertightness. Due to my lack of experience in electronics I'd like to stay away from anything complex, just a simple circuit. Any comments, suggestions or other ideas would be welcome. Just don't suggest shining a flashlight in, it works but getting a light out of my pocket in the car is what I'm trying to avoid. Lazy? Yes
Here are my specs-
*Low light output
