making a cheap Luxeon dome light?
Turbo_E
Turbo_E
i have an idea, thats probably been discussed before.
due to the massive drop in the cost of LuxIII's i bought a bunch. now i was thinking of having 2 emitters on a heatsink beind direct driven from my car's 12-14V DC. what would i need to bring the power down to what i need? resistors?
BIN are SX1K.
given that the Domelight already has a fluted/diffuser the LED wont be TOO intense.
ktronik
ktronik
Australia
would 4 emmiters fit?? as you could hook them up in series with no dropper resistor...this would be better as ballast resistors are a bit of a waste of power...
if you use only two, you would have to use a BIG 5w resistor, even if driving them @ 600ma...
food for thought...
enjoy
Ktronik
modamag
modamag
Bay Area, CA
turbo_e: It does not really matter what bin cause you're not doing white wall hunting so nobody will ever see the difference. Vf also doesn't matter since your car battery got more than enough, you're replacing a 10W bulb with a 3W LED :D And even Lux is not that much of an issue. I barely notice the difference between an S -> T bin under normal conditions. Almost any LuxIII you choose will be brighter and whiter than that inefficient 10W halogen bulb.
Here's what I did when I first joined CPF --> Luxeon Dome/Map Light Upgrade
Originally I used a 1x CC1WA & 1x TY0L for each bulb replacement. However the inductor on the CC1WA was causing interference with my remote so I later changed it to a LM317 + resistor (for 500mA output) + 2x LuxIII clones. It's brighter, cheaper and no interference.
Best of luck on your project.
ktronik: 4x LuxIII at one location might cause a thermal issue when you leave the door open for 20+ minutes. ;)
BatteryCharger
BatteryCharger
The crazy guy next door
Look into making an LM317 constant current driver. (search here and you'll find lots about it) It's extremely easy to make (just an LM317 and a resistor) and will drive up to 3 luxeons in series from 12v, at whatever current you decide to use.
PhotonWrangler
PhotonWrangler
In a handbasket
I would definitely drive it from a regulator, or at the very least put a 14v zener diode across the power input. A car's electrical system is pretty noisy and I wouldn't want a high voltage transient to find it's way into that Luxeon array.
Similar threads
mccavazos
Replies
16
Views
1K
UncleFester
UncleFester
T
Replies
3
Views
2K
trailstoride
T
K
Replies
5
Views
997
Mark_Paulus
Mark_Paulus
modamag
Replies
22
Views
11K
wasBlinded
W
