trout
I know some of you have been using the Makita lxt battery packs and that the cells are very robust .
my question is when I have been using my drill and the battery has drained to the point when it stops working the pack reads about 14 volts.
it is an 18 volt 3000mah pack by the way .
I am also using these batterys for my bike lights with the drivers from Taskled these allow a cut off at a preset voltage to protect the batterys from over discharge , so what do you think would be the correct voltage
for me to set my driver to for this low voltage setting ,
it can also be set for half drained and to flash a warning also what voltage would be half drained.
thanks
thanks
