Malkoff "Hound Dog"
dhunley1
Michigan
Yep, it's a champ. Bit of advice? I'd loosen the head for low beam while it's in your coat pocket. Our Aussie friend, XR6Toggie, recently melted down the lens on his HD 18650 by accidentally switching on the high mode while it was in his coat pocket.
I'm in the habit of keeping it in the low mode since it's what I use 90% of the time, and for the very reason you mentioned.
etc
Northern Virginia
Bump.
Writing to note that the hound dog offers a quantum leap over any 6p light, even by malkoff.
The throw, the spill, the flood and the lumens/runtime combination is a winner.
Hd xml has 3 times the lumens of m61 and much higher lux.
It is where high performance is.
flashy bazook
Bump.
true dat!
If you want Hound-dog XML type performance (not quite the same, of course) in the MD2 formfactor, look at the M61HOT.
If you want to beat the M61HOT, then go to the SUPER Hound-Dog!
etc
Northern Virginia
super hound dog exceeds the regular hound dog in one parameter, lux and thus throw.
it doesn't have its flood. Or its runtime.
Modernflame
Dirty Dirty South
I've said more than once that I could get by with only two flashlights: my MD2 with M61N and my Hound Dog 18650. I would not be happy about it, mind you. But I could survive. That is, at least until I could save up for a dozen other torches.
I take your point, but the spill on the Super's high beam is...well, super. It's dimmer than the reflector based Hound Dogs, but it's wide like a Wildcat and bright enough for your periphery.
Swedpat
Boden, Sweden
I agree. While the very wide spill can be a drawback, for example at snowy landscape with the spill dazzling against snow walls in the foreground, it definitely has its advantage for some purposes. I just imagine when walking in a forest at summer or a jungle where there are dangerous snakes and spiders. Then the wide spill will brightly illuminate the ground and the branches of the trees near around you.
And there are of course other situations when the wide spill is good to have.
I really like my 4000K Super Hound Dog! The warm tint is awesome!
Modernflame
Dirty Dirty South
I agree. While the very wide spill can be a drawback, for example at snowy landscape with the spill dazzling against snow walls in the foreground...
Interesting perspective. I actually hadn't considered that. In my part of the world, we get a light dusting of snow perhaps once a year. It lasts for about 12 hours before it evaporates in the sun.
I'm also content with my choice of 4000K for the Hound Dog Super. Some say that cool white is superior for a thrower, but I've had my neutral variant for about a year now and I've never regretted it.
INFRNL
Bottom Of Pikes Peak
Just joined the Hound Dog 18650 (neutral) club. What a fantastic light. 0421 s/n.
Does anybody know what the predicted Low runtime would be?
I have Low mode runtime on 2x rayovac primaries now, just need to make a chart. I'm going to charge a 18650 3500mah sanyo/panny cell and do another low mode test for comparison.
It's easy to say the primaries made it to 36hrs before i had to head out on the road and had to end the test even though it still had some output. However depending on one's use/needs; saying a light will run for 40hrs is not quite accurate.
With a graph ea individual can decide how much actual use they can expect for their use.
I will try to post the initial primary cell graph later tonight, I have plans so I cannot do it right now.
INFRNL
A slight update on the HD 18650 low mode runtime results. It appears that using a 3500mah sanyo cell will provide around double the runtime over primaries. I'm at almost 65hrs and it is still putting out around 1/2-3/4 lumen, it probably hit this mark around the 64hr mark so it should still be able to provide this amount of light for a while (I think).
I'm not sure when I'll call the test, but when I do, I will go through the results and make a graph. I would call the test now, but even though its only putting out around 1/2 lumen or so; it would still be usable if really needed (in very dark areas)
Modernflame
Dirty Dirty South
That's a very long time! It's good to know what to expect. Realistically, if I were depending on the Hound Dog's low beam, then it would be during an extended power outage. Since I sleep at night, I would only need it from sunset to bed time, which could be anywhere from two to six hours depending on the season. You could probably get two weeks out of it.
Question. What's the voltage on that cell right now? Is it unprotected?
INFRNL
I do not know what the current voltage is, I could take it out real quick to check. It's a protected cell., as you know I am not into unprotected cells.
BRB, with current voltage, I imagine it's getting down there though
Hot off the press it is @2.62v; surely it should be close to the cut off point, no? I thought these cells cut out around 2.7v or are at least supposed to
INFRNL
ok, the moment you have all been waiting for. I thought I ran the rayovac test longer but apparently not. I'll let you make your own conclusions/opinions as usual.
Brazil
What a beautiful test!
What a beautiful flashlight!
is certainly my favorite!
Thank you for your efforts to make this test a reality!
I already saved the graph to have along with the others :)
Do you intend to test in the high mode?
INFRNL
I have already done a High mode test with my old meter, but yes I was going to do it yesterday but lost track as i wanted to recharge the cell. I also already have high mode test on primaries but that test did not go too well. I can't remember what meter i did that test on.
I'll at least do the High Mode test with Sanyo GA 3500mah cell and post a chart and possibly post results along with low mode.
I have to redo some of my charts so that they appear as good as my current ones. Also if you send me your email, I can email you my excel files . I still need to get a couple charts to Mr Badger as well.
INFRNL
Thanks again for a the data, buddy. What was the voltage of your 18650 at the end of the test.
as of the moment, it has been my pleasure to do these and share them with those curious.
I honestly do not know what the end voltage was. I had a lot going on when the test ended and one of my nephews stopped by and I lost track of everything. This morning when i put it on the charger it was at 2.7x volts though. If I had to guess, it was probably close to 2.5x v. It almost made it to 70hrs but fell just a bit short. I think it only missed the 70hr mark by 2 minutes but output was really low near the end.
INFRNL
Here are the HD 18650 High mode results. Sorry, I lost the rest of my data for the primary results, but you will get the idea.
Edit: now that I think about it, the primary test could possibly have been done on the EA30 and i may have stopped the test. I honestly do not remember but you can see how the primaries will behave.
Here is a comparison to the initial test I did using the old meter (EA30). It appears there was a difference in my cells. At least they are close enough to be considered nearly the same
I forgot to edit the cell description. Blue is from the original test using the Extech EA30
INFRNL
Here is a HD XML MD3/MD4 comparison. I think the results maybe a little skewed. I plan to rerun both tests and see how they compare, but they are close; so I imagine new test won't be too far off.
