djblank87
I have searched and am unable to locate a solution. I emailed Gene and haven't heard back yet so I will try you guys.
I have owned over 10 M60's in my time but my current one is giving me trouble. I purchased it about 8 months ago. When I placed it in my SF 6P it did not light up like my others did.
I tried new cells and still nothing. While I was removing the bezel the M60 light up for a split second and then went out. I thought it was a grounding issue. So, I placed a small metal ring at the base of the M60, placed it in the 6P and it worked.
So for the past months I did not remove the bezel to avoid this problem. But, the other day I needed to remove it to wipe something off of the bezel. I cannot for the life of me get it (M60) to work again.
I tired my solution with the ring and got nothing. So, then I placed some tin foil around the base of the M60 and it lit up for a second then nothing.
I placed it into a Solarforce L2, didn't work. I tried three other 6P's, didn't work. I tried a G2, didn't work.
Has anyone had this problem and is there a way to fix it?
Thanks for the help..........
