Mjolnir
- Joined
- Dec 19, 2008
- Messages
- 1,711
I have a malkoff LED dropin (the SSC P4 type) in an older 3D maglite. Recently, I have noticed that the output of the light gets slightly higher every few times I turn the light on, right at the point when the switch "clicks" (when I only partially press the switch it is a lower brightness, but when the switch fully engages it gets noticeably brighter).
This is not consistent, and only happens every few times I turn the light on. It seems to me like I am losing brightness to the switch due to resistance somewhere, but I thought this was only a problem on higher amperage unregulated incandescent maglite mods.
Obviously something is wrong, since this should not be happening. Is there any way I can fix the switch (or reduce the resistance), or should I just buy a replacement switch?
