JNewell
It's probably worth mentioning that for the same cost you could get an MD4 tube and tailcap from Malkoff Devices, which will obviously be a perfect match for the Wildcat head.
Help Support Candle Power Flashlight Forum
How would you say the spill compares, is the Gen 2 a "circle"? The Gen 1 has the optic spill that fades to black, as opposed to a abrupt stop to the spill.
I received my gen2 Wildcat yesterday and immediately took it out on patrol to compare it to my gen1 Wildcats. But first, a little background...When I got my hands on my first M60, I said, "Wow!" I replaced all of my P60/P61/P90/P91 lamp assemblies with Malkoff drop-ins. I had M60 drop-ins in my Z2, in the 6P on my patrol rifle, in the 618FA on my short barrel shotgun at work, in a C2 at home, and in the 617FA of my personal shotgun. I also put M60L drop-ins into the G2s that I keep in my car and my wife's car. I toyed with a 9P with an MC-E drop-in but found that it didn't meet my needs, and I just received my first M61, which I will also put into the rotation.Now, I have a gen2 Wildcat in my hands. My reaction when I turned it on was, "WOW!!!" Why is it that Malkoff products keep impressing me again and again? As compared to the gen1 Wildcat, the gen2 Wildcat had noticeably greater output, a bigger hotspot, and a wider flood. I didn't notice the gen2 to throw significantly further than the gen1, but it illuminated items at a distance better than the gen1 simply because of the larger hotspot and the increased amount of light emitted. My gen1 is tinted ever so slightly to purple, while my gen2 is tinted very slightly to the green; but you would never notice unless you shined the beams alongside each other.
When I received my gen1 Wildcat, I again said, "Wow!!!" With it's compact size, great output, and perfect dual-mode momentary plus constant-on user interface; it immediately became one of my patrol lights. Shortly after, I was fortunate to get my hands on a warm gen1 Wildcat. Its huge hotspot and its wonderful warm tint made this light my go-to light for building searches. Yes, I carry two Wildcats on duty!
Adding excellent customer service to a fantastic lineup of products, I can wholeheartedly give Malkoff Devices and the gen2 Wildcat an enthusiastic thumbs-up! :twothumbs
(Sorry, folks. No pics. Someone else is going to have to handle that.)
You tell that the new Wildcat has wider flood as well, also seems surprising because it looks like beeing a typhical reflector light which usually has a narrower beam than the former Wildcat. Any beamshots?
Inside it's easy to miss the outer part of the total beam of gen1 Wildcat. I mean it's actually ~160deg or so!
You're probably right about the flood. The fact that the gen1 flood fades away and because the gen2 flood is so bright might have made the gen2 flood look larger.
Quick story before I run off to work.
Thursday night was my first night with the gen2. My officers know that I like expensive, powerful lights; and they knew I had just purchased a new one. Two of my officers had detained four subjects in an unlit picnic area of a park. I could see the pitiful beams from their SL20X flashlights as I approached. I announced my presence and positioned myself on a footpath overlooking the picnic area. I turned on my gen2 Wildcat which lit up the whole picnic area. One of the officers exclaimed, "Damn, Sarge!" Both officers simultaneously pocketed their flashlights and went on with their investigation. I just smiled.![]()
cons:
- PWM flicker on low with 2 x li-ion (not too bad though). Less noticeable on 3 x cr123.
