Question for you motorheads out there. Working on a 98 Buick Regal with a 3800 non supercharged motor. The low coolant light was staying on, during an internet search I learned that these motors have had MYRIADS of intake gasket problems. The car has 45k on it so I thought I'd go ahead and fix it straight away. Bought a Dorman upper intake repair kit and the new FelPro lower gaskets. Everything went fine, took me awhile since I don't do this everyday. When I opened the gasket set up, one of the end seals for the intake was missing. The car had been apart for two days, we needed it done. So I used blue silicone beads on the end seals. Everything was cleaned well and dry. During assembly the manifold was NOT moved at all. Torqued it in 3 steps in order, let it dry overnight. Finished job, car ran great, now it's leaking oil from the lower manifold on the drivers side. BUMMER! I have used silicone before on manifolds, actually it usually works better since factory end seals tend to slip out. Anybody have any suggestions on what might have gone wrong? I have checked some Buick forums, service info does not mention this happening. Plus a new gasket set is almost $75 too. Any suggestions? Thanks in advance. :sigh:
