Manker MK34vn II - Most Fav Popcan Flooder R
vinhnguyen54
Well-known member
CPFBA
Really the flooder to have. Finally a light that is more desirable to me than the X80GTvn.
Sorry the modded SDCE version is so expensive but its a pain to build.
The Stock XHP50.2 and SST40 are both wonderful though
https://skylumen.com/collections/v54-lights/products/manker-mk34vn-ii-2021-pocket-flood-king-r
[FONT=&quot]
[/FONT]
Sun Boy
Active member
Agree, appears to be a great light. Why do you like it better than the X80GTvn?
At what output could you run the XHP 50.2 for say 1 hour without excessive heat?
Also I have read getting the right size batteries can be difficult. What batteries do you recommend?
Thanks
Simon
vinhnguyen54
Well-known member
CPFBA
Agree, appears to be a great light. Why do you like it better than the X80GTvn? The triangular 3 cell body make the light noticeably smaller and easier to pocket and hold. I also prefer the Ui although Acebeam is good too.
At what output could you run the XHP 50.2 for say 1 hour without excessive heat? Some 2000 mark is my guess. I have not tested this.
Also I have read getting the right size batteries can be difficult. What batteries do you recommend? Stock, Lg 3500mah and Vtc5D all work fine.
X80GTvn is still brighter but much hotter and pricier.
I like this light enough that if price was irrelevant I would still pick this light over the X80GTvn.
Thanks
Simon
Sun Boy
Active member
Vinh,
You indicate the X80GT is much hotter. Is this only at high output levels?
I would have thought the X80GT at any given level would be cooler as it is slightly bigger. Is there another factor which makes it run hotter than the Manker?
Would either of these lights get uncomfortable running 1K lumens for long periods? I notice in another thread you were running the X80GT at 4K lumens for long periods.
Thanks
Simon
vinhnguyen54
Well-known member
CPFBA
Vinh,
You indicate the X80GT is much hotter. Is this only at high output levels? Yeah I meant its much hotter on turbo. LEDs are driven harder.
Thanks
Simon
vinhnguyen54
Well-known member
CPFBA
  • Stock MK34 SST40 5000K @2s: 14,000L, 36Kcd, 380m
  • Stock MK34 XHP50.2 6500K @2s: 20,500L, 40Kcd, 400m
  • MK34vn XHP50.2 6500K @2s: 23,500L, 47Kcd, 434m
  • MK34vn XHP50.2 SDCE ~5000K @2s: 21,000L, 58Kcd, 482m
