Help Support Candle Power Flashlight Forum
I'm happy to report the flickering seems to have stopped. Apparently it was a contact issue after all.
Geoff
I just ordered three (3) Maratac Polished Stainless Steel AAA flashights. I think they will make excellent Christmas gifts.:thumbsup:Now in a polished version!
Geoff,
Anything special you did to get the flickering on low to stop?
Thanks.
Andrew
Lay some 320 or finer grit sand paper on a solid, flat surface. Remove the head. Stand the body, open end first on the sand paper and give 2-3 gentle twists. Clean off with an alcohol rag. Q-tip the inside of the head with an alcohol swap. Re-lube with Nyogel or a bit of lithium grease for the stainless version and reassemble. That should take care of it.
Patriot,
Thanks for the suggestion. I gave it a try, but unfortunately the flickering is still there. It is only on low. Sometimes it doesn't start immediately, but only after maybe 30 sec. or so. Other times, it starts as soon as you turn it to low. Strange....
Mine has begun to do the same. Flickers only on low and may or may not flicker right away. Strange indeed! Still love the light though.
Sorry Austin. Worth a try I guess. Now that you mention it, if it's only happening in low, that pretty much rules out a contact fault. One of my lights, the natural HA one, does it every now and then but I had always suspected it was due to the 10440 I use in it.
