slipe
These numbers are about average for several references I found:
heat transfer coefficient
• Stainless steel - 21 W/mK
• Aluminum - 221 W/mK
One thing SS has going for it is that sandblasted it radiates about half as much heat as HA III, which is pretty good. Polished it radiates only about 20% as much.
MKLight's experience with the light not even getting warm after 5 minutes would give me pause. The light is producing the heat unless something is wrong with it.
I just put my black Maratac under a fan about two feet away blowing directly on it – much more than a light breeze. After two minutes on high (10440s) it was warm approaching hot. Not nearly as hot as it gets in still air, but it was quite warm. Most of the cooling is obviously from conduction since it is greater than in still air. But the HA III is also radiating more heat. I wouldn't be comfortable running a polished SS for five minutes on high with 10440s knowing all that heat was being trapped inside. I'm not comfortable running my black model for more than a couple of minutes on high with both better conduction and emissivity.
I don't think I would polish a SS Maratac and put 10440s in it. But not being a certified flashaholic I think of a light as a tool.
This is an interesting read: http://www.molalla.net/~leeper/coatbar.htm
I take issue with his saying high solids white paint has the same emissivity as black within a percent. Unless he has found a white paint he can put beside something black in the sun and get just as hot he is violating a basic law of thermodynamics. Kirchhoff's law says emissivity equals absorptivity.
