idleprocess
Rain is expected tomorrow and I really needed to get that trench filled before the piles of clay spoil dried and the compaction I would be able to realize would be even worse than the ~60% I realized; I will be combating subsidence along that trench for some time to come - likely with a number of lifts of sand so the grass grows through.If you haven't already filled in the trench, you might consider lying in the 12/2 cable beside your 6/3. If at a later date you want to update, you can drill another hole in the wall, and feed the 12/2 cable through.
It took me three evenings to do the trenching, then this evening to bury the wire.Even just 18 inches for 30 feet, depending upon the soil, rock content, or tree roots, can be quite a challenge.
Same here. I don't want to replicate this project well over twice as far for the future work.BTW... I really like power tools![]()
I read 18 inches for burying UF-B as NEC. This cable is expected to be energized for tens of hours a year, code for irrigation lines is a mere 12 inches, and freezing weather here is normally not continuous ... so I YOLO'ed it.I don't know what the code is for burying electrical cables, but if it is below the frost line, which around here is 3.5 feet, then a power tool rental would be an immediate YES.
