orbital
deal ended::::
deal ended::::
You are very welcome, and thanks for mentioning the Kestrel Drop, never heard of it (some googling returned this, which is what I think you are referring to: https://www.amazon.com/dp/B00JAKKNCG/?tag=cpf0b6-20).Yes dmenezes, now that you mention Bluetooth, I remember I have a kestrel drop that would be great for measuring the air temp blowing out of the generator. Fast response and has it's own memory for logging data. I would prefer cylinder head temperature and oil temperature but this is a good idea I can implement right away. Air cooled engines can be very hard on the oil.
Thanks!
Ouch! 60% sounds really abusive. Like, 20% a year?!Heat wave? This is nothing compared to what we will have during the next several months. I live in North East Texas. My 3 year electric contract expires next month, looks like at least a 60% increase in my bill for the contracts available these days.
Bob2650,<SNIP>
Back on topic: I bought a Toshiba portable AC/Heater (heat pump) with inverters rated 14,000 BTU (old method rating) 12,000 BTU (new DOE rating). It has NO big start-up surge. The inverters bring it up gradually and the Honda EU2200i runs it in ECO mode with no ugly noises or drama.<snip>
+1 on that recommendation. I need to see if there's something I can do with my old 2-hose unit to make it serviceable again because its single-hose replacement literally sucks.Also, most important for a portable unit is that it is essentially a TWO hose unit (a hose with in a hose).
Mere grid tie solar in TX is normally 20+ year ROI proposition; adding in enough production capacity + storage + ancillary equipment would easily double that.Isn't it worth yet to consider going off-grid, if not financially at least to give these guys the finger?
At this point I just wish the market would produce a window unit that mounts flush relative to the exterior since I have to maintain a clean exterior profile - otherwise I'd need to remove the bespoke solar screen which is ... difficult ... to access.
Yeah, I'm glad you agree with me about the single hose units. I don't understand WHY so many manufacturers produce the single hose units, and they are sold at the home depot. Honestly, I had not seen ANY two hose units at HD. I'm glad that Bob found them at his HD.+1 on that recommendation. I need to see if there's something I can do with my old 2-hose unit to make it serviceable again because its single-hose replacement literally sucks.
I've benchmarked this more than a few times and the TX market does not incentivize solar at all. Adding reasonable off-grid capabilities means a more expensive inverter as well as a pricey battery bank.Double that? noooo.
It's not going to take 40 years to break even.
Not much - discussion meandered a tad OT.What does this have to do w/ generators?
Cheaper, easier to install, they still manage to cool a room, and I suspect that pretty much the entire industry is now using the "pump condensate over the hot coils to improve efficiency and not require the user to deal with a drip pan" trick.I don't understand WHY so many manufacturers produce the single hose units
Thanks to the solar screen noone sees it as is.From the outside, all people would see is the plastic holder with the two hole ducts coming through it.
That was *before* the 60% price increase @Bob2650 mentioned, right? What about now?Mere grid tie solar in TX is normally 20+ year ROI proposition; adding in enough production capacity + storage + ancillary equipment would easily double that.
