Matching primary CR123A cells - by internal resistance or voltage?
Pontus.F
Hi
I just bought a bunch of primary CR123A cells from Fenix-Store, Panasonic brand, expires 2017. I have measured the open voltage of each cells as well as the load voltage through a known resistance with a calibrated Fluke 189 multimeter.
I now have a table with two columns: open terminal voltage and internal resistance (calculated from the load measurement).
My question: should CR123A cells be paired together using open voltage or internal resistance? Both make sense to me, but since the methods not always (very often though!) agree, I would like to hear from the battery experts out there.
Hello Pontus.F,
Welcome to CPF.
I would suggest matching with voltage under load.
How much variation did you find?
Tom
Thanks SilverFox. Since you are one of the more (the most) knowledgeable experts on batteries here on CPF, I will go for that.
Here are my results:
if the links dont work, look here:
http://picasaweb.google.com/pontusf83/Test/photo#5134677284668139090
http://picasaweb.google.com/pontusf83/Test/photo#5134677284668139106
http://picasaweb.google.com/pontusf83/Test/photo#5134678972590286450
