Matemico MT35vn Mini - Best Value Thrower R
B
bjs55
any way to shut off the light in the switch?
B
bigburly912
Virginia
I asked that before. Only way I know is to twist to disconnect. Don’t think there’s any other way
Newlumen
Newlumen
United States
I got my mt35vn white 2 mm.. it is truly an amazing light.. vinh stated 1000 lumen.. i got 1282 lumen with the acebeam protected.. kcd should be higher too. i did shine at the wall, and absolutely one of the best beam i ever seem.. no complaints here..
Newlumen
Newlumen
United States
Here is the mateminco mt35vn white 2.. skylumen get 1000 lumen. I got 1228 lumen @ turn on. As you see some of the light are escaping because of bezel.. let’s make it 1300 lumen. Amazing light !
F
flybird
Hi Newlumen , Have you experience any tint shift on Turbo when using High Amp cell as " b8llzblue " stated above ?
Newlumen
Newlumen
United States
i have only use acebeam 26650 protected and thrunite 26650 protected.. i am not planning to use high amp 26650.
Warranty card says 15a protected cells only.
S
SKV89
Newlumen, how does it compare to the Delta?
Newlumen
Newlumen
United States
Delta vn olson black is 750 lumen.. mt35vn white 2 is 1243 lumen... delta vn beam is more intense.. mt35vn reflector is alot bigger, therefore hotspot is bigger..
if you are spending $100, just go with a mt35vn white 2mm. it have built in charging unit for convience.. more brighter, and 470k cd.
Yes.. you can buy a stock mt35 for 3 times cheaper than vn, but 3 times less throw..
$100 for the mt35vn is great..
vinhnguyen54
vinhnguyen54
3 times less throw and no USA hassle free technical service ;-)
vinhnguyen54
vinhnguyen54
Actually it would be a hassle to repair this light should it break since the reflector is glued for a perfect beam .... YIKES hahaha
vinhnguyen54
vinhnguyen54
It seems White1.1 over White2 advantage is mostly in the smaller reflector lights as expected.
White1.1 6500L: 700L, 500Kcd, 1414m
White2 6500K: 1000L, 450Kcd, 1342m
Patriot
Patriot
Arizona
I'm ready for the White2.2!
Newlumen
Newlumen
United States
I personally think white 2 is the best.. more lumen, actually 1200 lumen, and less 50kcd.. guys buy white 2:
Patriot
Patriot
Arizona
Haha enjoy what is in the Now which is still pretty fresh ;-)
Hahaa! Yes, absolutely! It is new and the difference between W2 and W2.1 will be negligible.
Absolutely agree! It's loosing 30% lumens in order to gain 10% throw.
vinhnguyen54
vinhnguyen54
Best $90 thrower ever!
Similar threads
vinhnguyen54
Replies
27
Views
6K
wolfstyle
wolfstyle
vinhnguyen54
Replies
36
Views
11K
DayofReckoning
D
vinhnguyen54
Replies
41
Views
19K
vinhnguyen54
vinhnguyen54
vinhnguyen54
Replies
55
Views
17K
Patriot
Patriot
vinhnguyen54
Replies
467
Views
89K
vinhnguyen54
vinhnguyen54
