larryk
I have a Gen 2 Maxabeam and the later model Supernova with the Li-Ion battery. The Supernova outputs about 10% more lumens than the Maxabeam, but never had the tight spot of the Maxabeam. When shinning at a wall 15 feet away the Supernova's spot was almost twice as large as the Maxabeam's. Both lights set for tightest focus. Today I decided to remove the bulbs and see what, if any differences there are. As you can see in the photos the cathode and anode placement is different. Also the pin on the rear of the Maxabeam's bulb is tapered. I swapped bulbs and holy cow now the Supernova has a tighter spot than the Maxabeam ever had. The only drawback is there is only about 1/4 the flood, but I rarely use the flood option anyway. The Supernova bulb in the Maxabeam had a very large spot at the tightest focus. In the photos the Supernova bulb is always on top.
