I guess I'm not understanding what you mean then. But it is early then
Do you say the M61 HOT is a good performer because of its output? Because that thing is a battery hog and won't keep full power as long as say a standard M61. Or am I completely off of what your saying?
Yes, output: 740 lumens/20,000 lux is
good performance for a 6P size light, but still lagging. Bear in mind there are other U.S. made lights that double the lumens and exceed the lux by over 50% with a single 18650 cell, such as the SF Fury DFT and Modlite PLH.
Again, sacrificing output to achieve extended runtime (
for the sake of this discussion let's call that more than an hour) or keeping a light CR123A compatible is not what I or many other users are interested in.
This market segment is looking for (1) high output on a single 18650 cell; (2) a simple, nonprogrammable UI and (3) robust, high quality construction. Malkoff has the last two requirements covered perfectly, but is lagging in the output department in MD2 size lights as other manufacturers are finally abandoning support for the low-current CR123A.
One more I'll add to my wish list: a TIR lens, high-output head based on the Bodyguard step-down (take the M61HOT and let it run at 1,200 lumens and then drop back to 200-300 after eight seconds). At 4-3/4 inches long with a SF twisty tailcap running an IMR 18650, it would make for a very compact package;
