I came to the light...
- Joined
- Nov 4, 2007
- Messages
- 1,059
The short answer is no.
On these and other flashlight boards it is commonly assumed that the throw of a flashlight can be calculated by measuring the lux at one meter and using the inverse square law to determine the distance that the beam will reach. Or, since we are just feeding different numbers into the same formula, we can be spared the algebra and use the lux measurement as an indicator of throw.
There is a fundamental problem with this logic. I recommend that you read a bit about the inverse square law, and you will likely draw the same conclusion I did. In summary, it is a strictly geometrical law concerned with a constant amount of light spread over a quadratically increasing area. The law assumes a rate of dispersion equal to that of light emitted uniformly in all directions from a point source, but the purpose of a reflector or optic is to alter that rate.
I was fortunate enough to benefit from get-lit's extensive knowledge in this area. If you really want to understand the science behind a reflector and its beam of light, or if you just want to read an explanation more eloquent and detailed than my own, his posts make good reading. The conclusion is that reflectors of any type shape light as if it were coming from a point a certain distance from its actual source, the length of which depends on the reflector, and therefore the inverse square law is accurate if one corrects for that distance.
Small reflectors require only a small correction, which yields results fairly close to an uncorrected formula. However, as reflector size increases, so does the distance between the virtual focus point and the point measured to, making the unmodified inverse square law less and less accurate.
But what is all this talk without data? I have measured two flashlights at 1 meter intervals from 1 to 5 meters, one with a small reflector and one with a larger one.
Megalennium + SureFire KT4 + WA1185 with partially depleted batteries:
1m: 35500
2m: 10100
3m: 4550
4m: 2710
5m: 1644
Barbolight T14:
1m: 12680
2m: 3220
3m: 1400
4m: 812
5m: 517
Since the Megalennium is not regulated its output declined during the testing to 34,300 lux at 1 meter. To compensate for this I based my calculations on the data corrected by the corresponding fraction of the percent different in output, assuming a constant percent decline between measurements for lack of a better method. For example, the measurement at 3 meters was multiplied by 1 + (2 * (35500 / 34300 - 1) / 5. This is the corrected Megalennium data:
1m: 35500
2m: 10171
3m: 4614
4m: 2767
5m: 1690
According to the inverse square law, the formula should be: lux = (lux at 1 meter) * distance ^ -2, or
Megalennium: lux = 35500*distance^-2
Barbolight: lux = 12680*distance^-2
The average percent difference between the value predicted by these formulas and the actual measurements, or the average percent error, is 12.61% for the Megalennium, and 1.30% for the T14. While the T14's data seems to fit the curve, presumably due to the smaller reflector, the Megalennium's data is more than a little off.
I recalculated the formulas using the form lux = a * ( distance + b ) ^ -2, where a is the theoretical lux at the vitual focus point, and b is the distance between the point measured to and the virtual focus point. The resulting formulas are:
Megalennium: lux = 47092.32 * (x + 0.1517) ^ -2
Barbolight: lux = 13084.77 * (distance + 0.0158) ^ -2
These formulas yield only 1.80% and 0.69% error respectively, which can easily be accounted for with human error and procedural inaccuracy. I believe that the Megalennium data is less accurate because of my approximate compensation for output decline over the testing period.
The most important difference between the accuracy of the two sets of formulas is that the Megalennium formula's accuracy increased sevenfold, compared to the Barbolight's two times, an effect predicted by the larger correction in the Megalennium's formula.
Using these formulas to calculate the throw of each flashlight, or the point at which the target is illuminated by 1 lux, the distances change from 188 to 217 meters for the Megalennium, and from 113 to 114 meters for the Barbolight. So while the correction may not be necessary for flashlight as small as a pocket LED flashlight, the results are significantly different in flashlights with larger reflectors. I would assume that the difference would continue to increase with reflector size and collimation factor.
Based on this theory and supporting data, I would like to propose a slight modification to the standard for reporting the throw of a flashlight: measuring the maximum lux at both one and two meters. These measurements can be compared directly to those of flashlights with similarly sized reflectors, and can also be used to calculate throw distance in order to compare to flashlights of all reflector sizes if the reader so desires. Better yet, this added accuracy comes without considerable increase in effort on the reviewer's part, and can be ignored if the reader so chooses. Reviewers, are you signed on?
1m: 35500
2m: 10100
3m: 4550
4m: 2710
5m: 1644
Barbolight T14:
1m: 12680
2m: 3220
3m: 1400
4m: 812
5m: 517
1m: 35500
2m: 10171
3m: 4614
4m: 2767
5m: 1690
