vaniaspeedy
- Joined
- Feb 5, 2013
- Messages
- 1
Hi all, I'm looking for a flashlight, moderate size and better than average brightness, running on rechargeable eneloops. I don't know much about what the options are, so I'm open to suggestions and advice. Thanks!
Here's the usual checklist:
__X__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
__X__Less than $25.
3) Format:
__X__I want a flashlight.
4) Flashlight-specific format/size:
__X__Every day carry small (2-4 inches).
__X__Every day carry medium (4-7 inches).
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
__X__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
_X___I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
__X__I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
__X__I want to walk around an unlit rural area (50-150 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
__X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__X__5-20 yards/meters (check out a noise in the backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
__X__90-120 minutes (Runtime is moderately important, but still not critical)
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
__X__Slightly Important (Walks around the neighborhood).
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
__X__I don't care.
____I don’t know.
__X__A simple on-off with only one output level is fine for me.
__X__I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
____I want a beacon mode.
____I don’t care.
__X__I don’t know. (open to advice)
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
__X__I don’t care.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
__X__Wrist/Neck Lanyard
As you can see, I'm pretty open to suggestions/variations. I want a relatively low budget flashlight, but if something amazing pops up I'd be down to spend more. Thanks for the help!
__X__Less than $25.
3) Format:
6) Manufacturer:
__X__I don't care.
____I don’t know.
____I don’t care.
__X__I don’t care.
