Sold/Expired Megalennium 3x18650 by FiveMega
Status
Not open for further replies.
I think there would be a buying frenzy if he put them back up for offer though, i'm guessing there a quite a few people who havn't made there desire to buy one known but would bite your hand for one. I just hope i'm not on holiday if he decides to go ahead with them ...:mecry:
I'm hoping that five see's this thread...
I feel like he'll make them once more....
I would be in for another if the battery compartment was modified to accommodate the AW P18650 -26 without issues. I had to modify my cells so that they would make contact on the side with the three bumps.
[SIZE=+1]Sorry,[/SIZE]
[SIZE=+1]I can't keep the same price for run of small quantity and there is not enough serious interest for minimum quantity of 100 units. [/SIZE]
[SIZE=+1]Is there?[/SIZE]
FM - I think there is enough interest to do another run. You sold out your first round of over 100 units in just about 3 months and had people sorry they missed it. The Mega is mentioned nearly all the time in the threads and there are a ton of people who would buy if it was available but end up getting the 3x18650 baseball bat.
I was lucky enough to get one in the marketplace and I have yet to see more than one or two show up since then.
I already own one and I know I would buy another one should they become available again.
I'd be in for another ( I have 2) with the option that you make available an all parallel unit which is just a simple change in the battery plate,. I would love to do a long run time direct drive sst 50.
I'm hoping more people show interest.. As it stands, it's still a little light only because it's always free to say I want one
I'd be interested in one, but I do have a question.
Do I have to buy an M6 or are their sources to find just an M6 head? I figure the lamp assembly could be configured to a WA 1185 with a MN Socket.
I have recently acquired a tidy KT4, I would buy one as it is a far more useable format than a Leef 3x18650 (if you can even get one of those).
If these will work with a FM1909 bulb, I would be in for one more. If you could provide parallel battery plates, I would be in for a second one.
I use mine with AW IMR18650 cells and a FM1909 with now problem. A little more than 15 minutes of brilliant blinding light. I would recommend a SoftStart with this as that would be 65Watts through a clickie.
But technically 16340 IMR cells could also run the regular M6 with the FM1909. A 3S setup of 16340s will support 8C = ~4A and a 2P setup of that will support up to 8A. You'd have a touch more than 10 minutes of brilliance. I've done - it's great. 😀
The KT4 is not a thrower with the FM1909 so be prepared for about the same throw as a 1185 but with a hot spot about 3x the size.
Eric 242 is this an alternative for the M6 or another kind of thing altogether?
I wanted one for a Lumens Factory P7 Turbo Head but bought a Leef C-M 3x18650 body instead in the meantime. Unfortunatelly I received a 3x18650 C-C body today instead of the C-M and have to exchange it now :sick2:
Thanks for the reply and good luck.
HEY FIVEMEGA: I'd even prepay if required!
Status
