Sold/Expired Megalennium 3x18650 by FiveMega
Status
Not open for further replies.
:paypal:I'll take another #38. These are too good not to have at least two. Great job.
I apologise to anyone who asked for pictures eairler but I don't have that capability yet. I see that Donn got them done for those that wanted to see the inside of the light.
Paypal sent for #39. Ref 24585200F9319861W.
1x Megalennium
1x int shipping
total $127
I am also in for a Bi-Pin socket when they are available. Willing to pre-pay.
You also mentioned that you could do one without anodizing on the taper for use with the LZ led modules. I would be interested in this.
Thanks,
Oli
I received my Megalennium and can verify compatibility with my MZ LED modules.
The ano needs to be stripped from the head-side inner taper of the body, and the (+) contact screw adjustment has little room for error, but the module grounds against the taper before the head bottoms on the body.
I removed the ano by pressing out the battery end plate, plugging the hole at the bottom of the taper with a rubber stopper, and filled the taper with a sodium hydroxide drain cleaner. Five minutes and a quick scrub with some sandpaper and you're done. It is adviseable to mask the body or bubble mist from the chemical will attack the finish, doh!
For switching I went high-tech and used a screwdriver, but hopefully Mac will have a McClicky adapter available soon.
Very nice product Varooj! Amazing how you can do it for the asking price.
:twothumbs That's very good news. I have 2x of your modules coming, and I have 2x of the Megalennium. Together they are perfect marriages.
Varooj, is it possible to skip the andoize of the taper area on my Megalennium?
I received my Megalennium today and was excited about putting it all together when I discovered the rear battery connector is missing. Man, I am so bummed. I know FM will ship it to me but I was really looking forward to using it tonight. Having said that, the fit and finish on this beauty is awesome!!!!!!!!! Another great creation by FM!!!!
:mecry::mecry::mecry::mecry:
Varooj, if possible could you have the ano removed from the taper of the 2 bodies I have coming (as long as dimensions are maintained). If it's a hassle no problem, I'll just be more careful with the chemicals.
If your order is not shipped yet, I can ask anodizing shop to remove anodizing on tapered area of these bodies but there will be long delay on shipping. This is because I don't go there everyday and have no control on them.
Varroj, I'll take them as is. Thanks for the reply.
That's okay, just ship it as it is. I'll figure out something myself. EZ-Off cleaner? I need to talk to my wife. "Honey, I'll do the dish tonight..."
Oh man...I completely forgot about needing to have the ano removed from the taper! Could you please remove it from the taper for mine (#34) also??
:ohgeez:Sorry 'bout that!
:paypal:
(Unique Transaction ID #5SP62307W1533484R)
#43
1 x Megalennium plus shipping #43 ($119 + $6)
Please have anodize removed from taper. Incurred delay is fine.
Thanks!
Would also be interested in another run of the bi-pin adapters, as well as the McClicky adapter... FWIW! :twothumbs
EDIT: Thanks to niner's idea, I'll take the body as is, especially if it keeps you from incurring any additional expense at the anodize shop.
:paypal:
#44-#47 ,Four Megalennium plus shipping. (119*4+6+3*3=491) Thanks!
:paypal:
#43
Thanks!
I believe someone of you, like myself, don't want anodized taper area, because you are going to use M-Zeppelin LED heatsink.
I have a better soluton: use a spring to go between the bottom of heatsink and the host. I use a spring from P60 drop-in pill. I lathe the heatsink a little bit so the spring can positively sit on the heatsink. It works out great.
Status
