Some information about this small and cheap but awesome flashlight.
This light is similar to the Fenix P3D and the Jetbeam III Pro ST, on size, weight, beam and output power. So, let's compare them three.
The body knurling is much (but not too much) agressive than P3D's or Jet's. It provides a very good grip.
Interface is simple but handy: L-Mini II has a GITD reverse clicky with three modes: low, medium and high. The selected mode is memorized and restored each time the light is set on.
The L-Mini II has the same lenght than P3D's and the same weight than Jet's. Note: these weights are processed with batteries.
P3D Q5: 21.5 x 114 mm (0.85" x 4.5") - 84 g (3 oz)
L-Mini II Q5: 24 x 114 mm (0.94" x 4.5") - 123 g (4.3 oz)
Jet III Pro ST Q5: 26 x 123 mm (1.02" x 4.84") - 123 g (4.3 oz)
From left to right: P3D, L-Mini II, Jet III Pro ST:
Beamshots on a white wall::
Fenix P3D Q5
L-Mini II Q5
Jet III Pro ST Q5 (textured reflector)
Others beamshots are available there: http://lermite.nerim.net/beamshots/
The L-Mini II hot spot is bit tighter than P3D's and provides a better throw.
It has the widest spill of these threee lights.
The overall output looks more powerfull than the P3D's, and about the same or perhaps a bit more than Jet's.
The L-Mini II tint is nice, rather cool but very near of neutral white.
The power is very constant, and the driver provides a very nice feature:
instead of shutting down the light when the battery is drained, the light switch from high or medium mode to low mode wich last several hours. This allows to look for a new battery and to replace the drained one without being in full darkness and without using another flashlight.
With a 18650 Trusfire 2500 mAh:
In high mode, the L-Mini II switches on low mode after 2:17. It shuts down after 8:28 (including high mode duration).
In medium mode, it switched on low mode after 7:43 and shuts down after 11:19
The low mode lasts about 65 hours.
The L-Mini II Q5 is one of the smallest 1x18650 flashlight and maybe the best one because I'm unable to find any cons. It gathers the good sides of P3D and Jet ST, and even improved them. It would be the light I would choose if I had to keep only one.
This flashlight comes with a usefull holster, a lanyard, a replacement switch with black rubber and four O-rings.
Fenix P3D Q5
L-Mini II Q5
