MG PLI MC-E *review + beamshots*
What is the appeal of turn-bezel-mode-change?
It seems a step backwards to me to require both hands for setting the desired mode when it's a simple one handed operation using the clickie.
--flatline
It only takes one hand to turn on or off the light. Click the button and the light turns on, click again and the light turns off. The idea is that you turn the light on and off far more often than you switch modes. Essentially this makes it like a single mode light that you can transform to a different single mode light by using both hands and doing a loosen-tighten of the head. This also means you could have a forward clicky switch and you could use the light for morse code if you wanted. You can also hand the light to a non-flashaholic and say "press here to turn it on or off", confident that they will be able to work your light.
For someone that leaves it in one mode a lot the turn-bezel-mode-change is really good.
--flatline
I think the twist tail rather than the twist bezel is the perfect flashlight UI...especialy for bikes.
As a long time cycle commuter who uses flashlights I couldn't disagree more. You need two hands to twist, whilst just one to simply push the tailcap button. How would you change modes while riding or even while stopped with the light mounted on the bike if you needed to twist?
Why would you need two hands if the flashlight is mounted on the bike? Just reach and twist!
You'd need two hands to keep the light from twisting in the mount.
Nah..you can do a tail twist with one hand as easily as a push button....or at least I can. How loosely is your flashlight mounted anyway?
Well order one today and looking forward to brighten the masive darknes in Sweden now when its gettin pitch black 🙂 thanks for all opinions here , makes it easy to get what one need when all u ppl leaves feedback many thanks to u all / Micke
It's in a Two Fish mount. I ride every day to work, so a permanently mounted light is out of the question. What do you use as a mount?
You should get it very soon. SB has surprisingly fast shipping. I ordered mine on the 22nd of Sept and it arrived today in Latvia. Amazing.
HI: been using pli for 5months @ sheriff's dept it has pretty much taken the place of my fenix-tk11-r2 as a duty lite and @ my private reptile shop. The "intense" flood is just to much to believe, with 18650 i get weeks of lite, the three modes are icing on the cake!!
It sound pretty darned good!
:popcorn:
I hope mine arrives before the end of next week - should be so much fun to play with. I have a camping weekend and this should be a very impressive light due to the combination of fairly small light + incredibly bright output.
I have ordered some new 2600mAh 18650 cells from AW - should be good for plenty of run time.
How do you decide when it is time to recharge?
My order is in, t/y to those who helped. I'll follow up with my impressions when it has arrived.
PLI has arrived.
Edit: 1 day later, I turn it on and wth, Its flickering! All modes have a random flicker, very noticable. I tried reseating the battery and same effect. Whats going on with my new PLI?
Edit 2: 2 days later, flicker issue resolved, thank you lightbug(shiningbeam). Details are on the following page.
Condensed Short Review:
Bright, Solid, Useful size and beam.
Better Review & Obsevations:
Forward clicky was installed upon delivery, which was outstandingly speedy , from shiningbeam. I was worried about the UI before I got the PLI because I greatly favor bezel turn mode change, This UI hasent been such a problem like my AKO-ray 106. The 106 encourages you to leave the light off while it remembers the last mode (3 seconds off) the PLI encourages you to leave the light on while it remembers your current mode (3 seconds on), I find this setup much better and a big difference.. I'm not in the dark anymore.
Threads come pre lubed, dual orange orings seal the tailcap. The forward clicky is also orange. It can tailstand but barely, the button sticks out a hair so its the slightly leaning tower of Cree.
Overall shape fits great in my hand, better than my EagletacT100c2mk2, PLI seems more organic to hold, It also has roll stop feature. The finish is camo and just feels extremely durable, although im not sure other than that how to explain it. If I may use an analogy this feels like enamel paint vs normal paint (analogy only, I think its anodized?), I just get a 'feeling' however they did this finish it aint coming off, whereas oddly with the t100c2 it just feels like if I scratch it with my fingernail enough it will give, this dosent. Very smooth. Alittle lighter in weight than it looks, which is great.
The body has a square portion in the center instead of round all the way down the light.. I have an idea for mounting this square portion in a mount to a shotgun, If and when I do this we'll see just how much punishment this PLI can take.
The OP reflector looks as deep and round as the T100c2, 'defensive' bezel is slightly more aggressive than the eagletac and looks about par for the course.
This is my first multi die emitter. When compared to the eagletac, imagine the main 'cone' of light from the eagletac, even out the beam (t100c2 smo is laserishly tight focused) and up the power significantly.
The spill to the sides is also multitudes brighter and much more useful than the ET, ultimatly I'd like some more spill straight to the sides as I intend this to be an up close light, but not everybody can afford a Malkoff MC-E (case in point:me).
This light does actually throw quite good, despite the OP reflector and MC-E and the small shape of the light, It really is a pocket burner. Strangely out to 75ish yards (yes YARDS) with the very much flood oriented beam I would still actually take this over the narrow t100c2, even at that far distance it lights up objects (all of them lol) well enough. This is in pitch darkness though.
I was also worried about the WC Tint before it arrived as I'm outdoorsy and prefer warm -and I still would- over cool. However It dosent look cool to me, just very bright and I havent had any trouble seeing anything. You get a real sense of the amount of light it takes to project a solid cone of brightness, a sense I just dont get with the eagletac. This does have a bright hotspot center, which is phenomenal for such a floody beam, again.. thats a powerful light.
Its 3 modes are in my opinion, Ideally spaced to encompass a variety of tasks, I do find myself blasting this on high most of the time.
Conclusion:
MG seems to have balanced this light so well.. I just may have to get another. They have balanced very usable spill, a supreme flood, plus a significant hotspot in a regulated 18650 rugged lighterweight body, and gave it all to me for under $55.
stealth
Very good and intresting report , Stealth .
So your light has a hot spot in the center , rather than a slight donut dark spot that some have reported .
I wonder , did you get a pick-of-the-litter , or if they have been improved and they all have a hotspot now ?
Can anyone else with a recent one confirm that the dark spot between the 4 dies is now gone from the beam ?
I don't see much dark spot in the beam centers in the beamshots on the first page , but some have reported it and say that loosening the bezel improves it. I'm hoping this adjustment is no longer necessary .
All you have to do is twist the head to the right spot and all of the Mg Pli's are donut hole free.
Stealth be sure the switch retaining ring in the tailcap is tightened down tight. I have the slightly older model and the ring comes loose every time I unscrew the tailcap. I'm sure you have a newer model so I don't know if those have that problem or not. Other than that not sure what to tell you besides try a different battery and clean the contacts.
Shiningbeam will take care of you if you still have problems.
