ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I'm glad I waited a couple of weeks to purchase the MG RX-1 Version 2 Q5. I did not know there was going to be an improved version. This version has a different shaped reflector for more throw.
The reflector screws into the lens bezel assembly. Similar to how Dereelight does it with the DBS V1 and V2. Uses a SMO reflector.
Circumference - 52.85mm or 2.080". Length - 41.76mm or 1.644"
The rear switch is also able to handle 3A.
Installed is a reverse clickie.
Inside view of the rear clickie.
I do not have the first version so I can't compare the reflectors to see the throw or overall beam shape.
The battery tube uses some thick o-rings. O-rings came lubed.
The finish is Type II Anodize which is done very good. All body parts match very good.
All MG RX-1 Version 2's comes serialized.
It says on the other side "Bright Your World' which the light actually does. I am amazed how bright the beam is. The MG RX-1 Version 2 uses a CREE XR-E Q5 Emitter, silver core. My beam tint is white.
Uses 3 levels, high, medium and low. 1200 mA on high mode, 300mA on medium, and 100 mA on low. Remembers the last setting when selected off.
Input voltage 2.8-4.2V
Uses 17670 or 18650 sized battery. Do not use 2 CR123's or RCR123's!!!
Voltage cut off 2.7V
Boost/buck circuit board.
The CREE XR-E Q5 Emitter, silver core.
I had to use some pliers to remove the Cree module.
The MG RX-1 Version 2 feels well balanced in my hand.
The light came with all these goodies.
___________________________________________
Size comparisions.
Left to right, MG RX-1 Version 2 Q5, Tiablo A10 R2, Dereelight DBS V2 Q5
____________________________________________
These are the lux readings I got.
I used AW's Black Protected 18650's in all the lights.
I choose the Q5 for the Dereelight DBS V2 because the R2 I have for the DBS got lower lux readings.
MG RX-1 Version 2 Q5 (High) - 23,779 lux @ 1 meter
MG RX-1 Version 2 Q5 (Medium) - 10,006 lux @ 1 meter
MG RX-1 Version 2 Q5 (Low) - 4,012 lux @ 1 meter
Tiablo A10 R2 - 27,115 lux @ 1 meter
Dereelight DBS V2 Q5 - 20,767 lux @ 1 meter
MG RX-1 Version 2 Q5 @ 96"
Tiablo A10 R2 @ 96"
Dereelight DBS V2 Q5 @ 96"
Left, MG RX-1 Version 2 Q5. Right, Tiablo A10 R2 @ 96"
Left, MG RX-1 Version 2 Q5. Right, Dereelight DBS V2 Q5 @ 96"
Left, MG RX-1 Version 2 Q5. Right, Tiablo A10 R2 @ 96" Stepped down exposure
Left, MG RX-1 Version 2 Q5. Right, Dereelight DBS V2 Q5 @ 96" Stepped down exposure
MG RX-1 Version 2 Q5 (High) @ 32'
MG RX-1 Version 2 Q5 (Medium) @ 32'
MG RX-1 Version 2 Q5 (Low) @ 32'
Tiablo A10 R2 @ 32'
Dereelight DBS V2 Q5 @ 32'
MG RX-1 Version 2 Q5 @ 146' or 44.5 meters
Tiablo A10 R2 @ 146' or 44.5 meters
Dereelight DBS V2 Q5 or 44.5 meters
MG RX-1 Version 2 Q5 @ 210' or 64 meters
Tiablo A10 R2 @ 210' or 64 meters
Dereelight DBS V2 Q5 @ 210' or 64 meters
Pros
Price
Comes with extra o-rings, lanyard and rear switch.
Uses thick o-rings. O-rings came lubed.
No strobe or SOS.
Parts not glued.
Cons
Type II Anodize, I wish the MG RX-1 Version 2 came with Type III Hard Anodize.
No holster
Cannot use 2 Cr123's or 2 RCR123's.
The lens seems "not clear". I cleaned the lens with some lens wipes but it looks the same.
I really like the MG RX-1 Version 2. The cost was only $49.70, a budget thrower at a good price.
I am amazed at how bright the MG RX-1 Version 2 is.
I like that there is not annoying strobe or SOS.
If you want to use this light to read in the dark it's not very good. These "thrower" type lights have a very bright hot spot. It's due to the SMO reflector. If it had an OP reflector and a lower low then I think it would be OK to use to read at night.
I like how the light remembers it's last setting when selcted off. I don't like the lights that you have to go through all the settings to shut it off. I have a tendency to leave the light on after 1 click because I forget to cycle through all the levels to shut the light off.
I did order another MG RX-1 Version 2 for work. The light I take to work will get some abuse. The other light will be a "shelf queen".
The fit and finish was very good. I was surprised because I read that the earlier versions had some flaws in the finish. I like how thicker o-rings are used and that they came lubed.
I guess if the MG RX-1 Version 2 came with a holster and Type III Hard Anodize the price would be much higher.
Size comparisions.
Tiablo A10 R2 @ 96"
Tiablo A10 R2 @ 32'
Pros
Price
No strobe or SOS.
Parts not glued.
Cons
No holster
