whc
Borrowed this monster to do a review for a Danish website, thought why not post a mini review here also .
This is my first tryout with the HID bulb, have dedicated myself to the LED, so don't have any other HID to compare with, and it is really an unfair challenge between a HID flashlight and a LED flashlight.
Specs from the manufacturer:
Fit and finish is perfect, seams very well made, no flaws in HA (appears to be only HAII though), and machining is without any marks.
This is really a big flashlight in its class, manufacturer uses the term "tactical" flashlight, though did not find it comfortably to hold when using it for tactical purpose, and the HID bulb takes about 1 seconds to reach full output, not ideal for momentary tactical use IMO.
The switch is really nice though, it is a true forward clicky which is very smooth and silent, reminds me about the one in my VB-16, with has about the same smoothness and silence, like it allot.
You can set the focus of the beam by turning the bezel ring, and then turning the head left or right, to obtain just the right amount of throw or flood, and then you tighten the bezel ring. Though am missing some more throw, even though the hot spot is pretty tight, still not as tight as some of the throw monsters of the LED lights.
Surprisingly the tint is very white, more towards the cool white, but no yellow at all as I personally was expecting.
Well enough readings here is some images .
From left: WarriorIII, WF-500L, VB-16 4th gen., L1D-CE, 120P, LF2
Now to some beamshots .
Left: WarriorIII, Right: WF500L with SSC P4
Left: WarriorIII, Right: WF500L with SSC P4, 2-stops underexposed
Left: WarriorIII, Right: VB-16 4th gen.
Left: WarriorIII, Right: VB-16 4th gen., 2-stops underexposed
WarriorIII
WF500L (same place)
Left: 120P, Right: WarriorIII
Left: 120P, Right: WarriorIII, 2-stops underexposed
More WarriorIII throw shots
Could not take overall lux readings, since the head was too big to fit in my lightbox, so only throw is what I can provide for this review.
Luxreading Throw: 105300 Lux (yep hundredfivethousindtreehundred)
Runtime: 59 min 02 sec, very flat output, did not notice any drop in output.
thats all folks .
Arrived in two nice gift boxes, where the flashlight itself is in the one box, and the charger in the other box. The flashlight came disassembled, that will say the body and head was in each own compartment in the box.Specifications:
Feature: HID (High Intensity Discharge) handheld tactical / searching flashlight, instant activating
Model: K3500R
Bulb: K3-HID-Bulb, lifespan 3,000 hours
Power: 35W
Colour temperature: 7000K
Beam divergence adjustable: 15¡ã - 24¡ã
Runtime and Brightness: 3500 lumens max / 55 minutes approximately
Switch: tactical button switch
Body: Aircraft grade aluminium CNC, hard anodized
Housing diameter: 44mm
Bezel diameter: 76mm
Length: 252mm
Weight: 800g approximately
Water resistant: splash proof
Operation temperature: -10¡ãC ------ +60¡ãC
Color: Tactical black
WarriorIII
WF500L (same place)
thats all folks .
