I know this is probably the simplest mod in the world, but I managed to muck something up. I am trying to upgrade a 2AA Mini Maglight to an LED bulb. I got the LED upgrade kit (bulb and reflector) and pulled out the old incandescent. I also pulled out the plastic piece that says "Do Not Remove". (This was probably my mistake.) Now, when I put the light back together (with either the LED or old bulb) it does not light up.
Batteries are good, putting out 3.0V combined. I also tested both bulbs with a 3V power supply and they light up.
Are there pictures of this procedure anywhere? Now that I am troubleshooting this, I can't figure out how the negative battery terminal connects to the LED. There appears to be no metal contacts to complete the circuit. Did some small part spring out when I ripped out the "Do Not Remove piece? Where exactly should the leads from the bulb fit in?
What else could be wrong?
