HarveyRich
- Joined
- Oct 5, 2006
- Messages
- 434
Just received this light from Kaidomain, which works with RCR123A 3.7V li-ion cells. That's what I used for my single run-through (LIR 3.6v unprotected 800mah). The aluminum casing is thin, but well machined and seems to be of fairly high quality work. It flickered a little when I first twisted it on. The ground wire was soldered to the bottom of the head (or pcb?) inside with a blob, which was uneven, so I put some extra solder around there which seemed to help the flicker a bit. It now flickers a bit when twisting on and off, but not while on.
The Kaidomain site claims that this lite was tested at 4100 lux at one meter. I sure didn't get anything near that amount of light in the hot spot. However, it still threw a very nice large bright spot with about 2650 lux with a freshly charged battery. So, beware of the claim on the site, but it's still very nice output.
I ran it for 35 mins by which time the light output was down to about 1350 lux or slightly over 50% of the initial output, I would estimate. Battery voltage then was 3.6v. I put the battery back back in and turned the light back on, running it to about 42 mins before the light had significantly declined to 1/4 or less of the original output (eyeball estimate). Since I had an unprotected battery, I pulled it at that point. The voltage tested 3.22v and I had no problems charging it back up again. The light became fairly warm to the touch during the run, but not that warm that it felt hot.
In conclusion, I liked this light, despite the runtime limitation. I would say that you can expect 40 minutes of effective light before you run the danger of over discharging your unprotected li-ion battery. I guess that's not too bad for a light of this size and output on RCR123A batteries. In comparison, my LOD-CE had an output on 10440 on high of about 1,500 lux at a meter and 525 lux on medium. From other threads, I gather that it runs about 12 mins on high. So, these numbers are really not bad at all. The only downside for me is that there's only one output setting, i.e. no medium.
Edit: Oh yes, the hotspot is fairly large, focused and white. There's useable spill, but not as much as with the LOD-CE.
