I decided to test the temperature profiles of two Sanyo chargers.
I used four 'normal' AA eneloops (HR-3UTG) discharged to around 1.20V resting voltage (even though some had climbed up to 1.22-1.24 after a day).
Sanyo MQH02 Super Quick Charger: Will charge two AA eneloops in around 60 minutes according to the datasheet (charge current is 2 x 2140 mA).
Sanyo NC-TGR02: Will charge two AA eneloops in around 230 minutes according to the datasheet (charge current is 2 x 550 mA). It is part of the eneloop charger line released together with the new 1500-cycle eneloops (HR-3UTGA). It just says 'eneloop' on the front.
Here is the testing in progress:
(the HR-3UTGA cells in the center are not tested, maybe another time)
and here are the results:
These are maximal temperatures (one cell is cooler, and one of them terminates earlier than the other).
The MQH02 terminates after 53 minutes and the cell voltages are (after one minute or such): 1.48 and 1.46 (terminated earlier).
The NC-TGR02 terminates after 254 minutes(!!) and the cell voltages are 1,45 (terminated after 216 minutes) and 1.49. Maybe it took longer because it is a wall-wart type and it was laying down, but I will just write that up as another negative with wall-wart type chargers.
Another diagram with only the MQH02:
I think the MQH02 termination is quite impressive, it terminates just after delta-T exceeds 1 degree C/minute, which is the ideal termination condition according to the Duracell datasheet and others.
It would have been more interesting to try the NC-TGR03 (Two AA eneloops in 100 minutes, also part of the new line) instead of the NC-TGR02, but it is quite expensive and another dreaded wall-wart. I also don't collect nor need more chargers. It seems that neither charger have any trickle charge (I know that the MQH02 doesn't)
MQH02 is clearly the winner in my book.
