No worries about that. One of the main things that's been keeping me away from rechargables is an easy way to verify that the batteries actually do what they say on the label. I love the discharge testing capabilities of this thing, they let me quantify that the batteries are actually good.
In my case, I almost *never* replace alkalines because they're discharged, I'm almost always replacing them because they're leaking - hence my interest in completely getting rid of them.
I do have some lithium-ion batteries, mostly for use in flashlights, and the Opus charger should be great for those as well. I'll look into acquiring one of these BQ-CC17 chargers. Thanks for the pointer.
I should have clarified that I'm in Canada. Most of the deals you're referencing are not available in this market.
I'm in the process of testing some Olight branded NiMH. So far, for general constant usage and recharging, theyre testing well. I have 24 of them, and a control group of 8, which I have fully topped off once then fully drained and charged, and am letting them sit for a year, after which I'll top them off and record how much they topped off at, then I'll drain them and fully recharge them and test again. -my poor man's LSD (LOL) test.
I'm from the "olden NiMH break in days", but I'm sure with their factory testing they've PROBABLY been broken in.
12 of the cells have been drained multiple times and fully charged. Their out-of-package top off values were an average of 870mAh, out of a 2500mAh rating. Their full charge values all exceeded 2500 mAh, with an average of 2562mAh +40/-31.
The unscientific drain test was to use specific flashlights with known amperage draws, then letting them run until measured voltage was around 1.1v, a few as low as 0.9v. Some of the lights didnt have a termination/low voltage cutoff, so I had to set a timer to avoid killing the cells.
In short (or long), I'll have an idea as to whether or not they are low self discharge in a year, and we will see how the cells hold up to intermittent use vs. Every day hard use. As they're only rated to a few hundred charges, we will ALSO know within a year (likely a few months) just how many charges it takes until the performance begins to degrade. I've been running the battery (heh) of tests since I got them roughly a week ago, and have been doing it for about 12 hours a day, so each cell gets a fixed set of tests a day.
They have a "special offer" for members, it's like $7 for 8 cells. Also, I'm testing a couple pairs in a couple of wireless outdoor cameras, and while they show "low charge", they seem to be providing enough current to run them for now. I'll also keep you guys posted on that situation.
