Hi there. I have a couple of questions.
Would it be ok if a person mixed Duraloops and Eneloops in the same light if they had to?
I know the golden rule of never mixing brands but wouldn't these be an exception?
Thank you.
"If they HAD to" sure. But I wouldn't do it just because you're lazy. I don't think it would be that big of a deal especially if the batteries are fully charged first, and, you don't fully discharge them.
But, as others have said I don't like to mix different battery batches. Doesn't mean I don't though....
(I've been known to use 2007 Duraloops with 2009 Duraloops, but I checked their capacity first)
I will be using six AAA LSD cells to power a modified 2C Maglite ... Since all my AAAs are either 800mAh or 820mAh , I will probably use two different makes ... I will be using two 3AAA cassettes that come in those cheapie 3AAA torches ... The light output will be well over 400 lumens , possibly near to 600 lumens ... I will have for example one cassette with Eneloops in and the other with either Hybrios or GP Recykos."If they HAD to" sure. But I wouldn't do it just because you're lazy. I don't think it would be that big of a deal especially if the batteries are fully charged first, and, you don't fully discharge them.
The worst that would/could happen, is that one of your batteries would get reverse charged and most likely ruined. It's not going to blow up or anything like that.
x2... I dont think theres any immediate harm or danger. It could set precedence for lazy habits to develop though. If you were to accidentally mix a Chinese black-top cell with a legit Japanese white top duraloop... that could be trouble.
If you have two batteries of identical mAh capacity but with different internal resistances , I assume that the one with the higher resistance will warm up more than the one with the lower resistance under load conditions.I think the bigger problem would be mixing the chinese and japanese as they probably differ in the internal resistance which would make one discharge faster than the other when paired together so even if the capacities were identical the discharge rate could differ to the point of one being depleted faster than the other increasing the chance of reversal in some devices even more.
