Once you match a set of cells by measuring their capacity with the C9000 wouldn't the next step be to measure the energy required to recharge each cell after being discharged as a set? For example, match two cells by measured capacity then place them in a flashlight (2 AA cells in series), discharge approximately 2/3 of the cells capacity, then compare the amount of energy required to recharge each cell...
jt4703's non-text URL in:
Mixing NiMh brands got me to read this thread again and I see no one ever replied (I wasn't feeling
too hot health-wise the first time I read it and I
meant to get back to it...
The impression I got the first time I read this was "
This is a 'Trick' question, right?"
😕 and, almost a week later, I feel the same way. From everything I've learned, as a hobbyist - not an engineer, CURRENT in a SERIES circuit is constant (and VOLTAGE in a PARALLEL circuit is constant). We make use of this 'Constant CURRENT Rule' when we use a resistor to measure the INTERNAL RESISTANCE of a cell.
If I discharged a pair of LSD NiMH cells in my C9000 @ 100mA and it came up with ~1900mAh, then if I put that pair into a device that draws 100mA, ~19 hours later they should be empty. When I recharge them, both at the same rate / time / temperature, they should terminate at approximately the same time (i.e. take in the same amount of charge).
Why would you think otherwise? :thinking:
...Would the recharged capacity be close or the same if both cells had the same capacity and different internal resistance?
I'd say
NO! If they had
different internal resistance, they would also have different measured CAPACITY.
I've been going through my *CRAP* cell today and discovered something applicable:
Code:
NiMh Rayovac AA 1600ma 1: 04/10/09 - 1.55VDC (Impedance Check C9000) ENV-Y
NiMh Rayovac AA 1600ma 1: 02/19/09 - 1299mAh (Refresh3 BC-900 200) ENV-Y
NiMh Rayovac AA 1600ma 1: 02/xx/09 - 1298mAh (Refresh2 BC-900 200) ENV-Y
NiMh Rayovac AA 1600ma 1: 02/xx/09 - 1218mAh (Refresh1 BC-900 200) ENV-Y
NiMh Rayovac AA 1600ma 1: 02/15/09 - ---mAh (Charge RadioShk140/13) ENV-Y
NiMh Rayovac AA 1600ma 2: 04/10/09 - 1.55VDC (Impedance Check C9000) ENV-Y
NiMh Rayovac AA 1600ma 2: 02/19/09 - 1228mAh (Refresh2 BC-900 200) ENV-Y
NiMh Rayovac AA 1600ma 2: 02/xx/09 - 1093mAh (Refresh1 BC-900 200) ENV-Y
NiMh Rayovac AA 1600ma 2: 02/15/09 - ---mAh (Charge RadioShk140/13) ENV-Y
NiMh Rayovac AA 1600ma 3: 04/10/09 - 1.52VDC (Impedance Check C9000) ENV-Y
NiMh Rayovac AA 1600ma 3: 02/11/09 - 1209mAh (Break-In C-9000) ENV-Y
NiMh Rayovac AA 1600ma 3: 02/09/09 - 1286mAh (Discharge C-9000 100) ENV-Y
NiMh Rayovac AA 1600ma 3: 02/08/09 - 170mAh (Charge C-9000 800) ENV-Y
NiMh Rayovac AA 1600ma 3: 01/19/09 - 1378mAh (Refresh BC-900 500) ENV-Y
NiMh Rayovac AA 1600ma 4: 04/10/09 - 1.52VDC (Impedance Check C9000) ENV-Y
NiMh Rayovac AA 1600ma 4: 02/11/09 - 1201mAh (Break-In C-9000 ) ENV-Y
NiMh Rayovac AA 1600ma 4: 02/09/09 - 1268mAh (Discharge C-9000 100) ENV-Y
NiMh Rayovac AA 1600ma 4: 02/08/09 - 191mAh (Charge C-9000 800) ENV-Y
NiMh Rayovac AA 1600ma 4: 01/19/09 - 1368mAh (Refresh BC-900 500) ENV-Y
NiMh Rayovac AA 1600ma 7: 04/10/09 - 1.50VDC (Impedance Check C9000) ANL
NiMh Rayovac AA 1600ma 7: 02/14/09 - 1236mAh (Break-In C-9000) ANL
NiMh Rayovac AA 1600ma 7: 02/12/09 - 1241mAh (Discharge C-9000 100) ANL
NiMh Rayovac AA 1600ma 7: 02/11/09 - 300mAh (Charge C-9000 800) ANL
NiMh Rayovac AA 1600ma 7: 01/21/09 - 1280mAh (Refresh BC-900 700) ANL
NiMh Rayovac AA 1600ma 7: 01/20/09 - ----mAh (Charge BC-900 1500) ANL
NiMh Rayovac AA 1600ma 7: 01/20/09 - ----mAh (Charge BC-900 1800) ANL
NiMh Rayovac AA 1600ma 8: 04/10/09 - 1.53VDC (Impedance Check C9000) ANL
NiMh Rayovac AA 1600ma 8: 02/14/09 - 1225mAh (Break-In C-9000) ANL
NiMh Rayovac AA 1600ma 8: 02/12/09 - 1228mAh (Discharge C-9000 100) ANL
NiMh Rayovac AA 1600ma 8: 02/11/09 - 176mAh (Charge C-9000 800) ANL
NiMh Rayovac AA 1600ma 8: 01/22/09 - 1220mAh (Refresh BC-900 700) ANL
NiMh Rayovac AA 1600ma 4: 04/10/09 - 1.69VDC (Impedance Check C9000) ANL
NiMh Rayovac AA 1600ma 4: 02/14/09 - 1188mAh (Break-In C-9000) ANL
NiMh Rayovac AA 1600ma 4: 02/12/09 - 1238mAh (Discharge C-9000 100) ANL
NiMh Rayovac AA 1600ma 4: 02/11/09 - 191mAh (Charge C-9000 800) ANL
NiMh Rayovac AA 1600ma 4: 01/24/09 - 1319mAh (Refresh BC-900 700) ANL
NiMh Rayovac AA 1600ma 2: 04/10/09 - 1.93VDC (Impedance Check C9000) ANL
NiMh Rayovac AA 1600ma 2: 02/11/09 - 1147mAh (Refresh BC-900 200) ANL
NiMh Rayovac AA 1600ma 2: 01/20/09 - 714mAh (Refresh BC-900 1000) ANL
NiMh Rayovac AA 1600ma 3: 04/10/09 - 1.57VDC (Impedance Check C9000) ONN-Y
NiMh Rayovac AA 1600ma 3: 02/11/09 - 1184mAh (Break-In C-9000 ) ONN-Y
NiMh Rayovac AA 1600ma 3: 02/09/09 - 1086mAh (Discharge C-9000 100) ONN-Y
NiMh Rayovac AA 1600ma 3: 02/08/09 - 917mAh (Charge C-9000 800) ONN-Y
NiMh Rayovac AA 1600ma 3: 01/21/09 - 1354mAh (Refresh BC-900 700) ONN-Y
NiMh Rayovac AA 1600ma 1: 04/10/09 - 1.68VDC (Impedance Check C9000) MTB
NiMh Rayovac AA 1600ma 1: 02/11/09 - 1174mAh (Break-In C-9000 ) MTB
NiMh Rayovac AA 1600ma 1: 02/09/09 - 1219mAh (Discharge C-9000 100) MTB
NiMh Rayovac AA 1600ma 1: 02/08/09 - 185mAh (Charge C-9000 800) MTB
NiMh Rayovac AA 1600ma 1: 01/24/09 - 1365mAh (Refresh BC-900 700) MTB
NiMh Rayovac AA 1600ma 2: 04/xx/09 - ----mAh (Break-In C-9000 1600) LNH-Y
NiMh Rayovac AA 1600ma 2: 04/10/09 - ----mAh (Discharge C-9000 100) LNH-Y
NiMh Rayovac AA 1600ma 2: 04/10/09 - 1.72VDC (Impedance Check C9000) LNH-Y
NiMh Rayovac AA 1600ma 2: 02/15/09 - 1160mAh (Refresh2 BC-900 200) LNH-Y
NiMh Rayovac AA 1600ma 2: 02/xx/09 - 905mAh (Refresh1 BC-900 200) LNH-Y
NiMh Rayovac AA 1600ma 2: 01/28/09 - 1214mAh (Refresh BC-900 500) LNH-Y
NiMh Rayovac AA 1600ma 2: 01/18/09 - 1216mAh (Refresh BC-900 1000) LNH-Y
NiMh Rayovac AA 1600ma 2: 04/10/09 - 1.84VDC (Impedance Check C9000) MTB
NiMh Rayovac AA 1600ma 2: 02/14/09 - 1125mAh (Break-In C-9000 ) MTB
NiMh Rayovac AA 1600ma 2: 02/12/09 - 1108mAh (Discharge C-9000 100) MTB
NiMh Rayovac AA 1600ma 2: 02/11/09 - 149mAh (Charge C-9000 800) MTB
NiMh Rayovac AA 1600ma 2: 01/28/09 - 1288mAh (Refresh BC-900 500) MTB
NiMh Rayovac AA 1600ma 2: 01/24/09 - 1198mAh (Refresh BC-900 700) MTB
During the C9000 IMPEDANCE CHECK, the voltage momentarily displayed corresponds rather nicely to the measured CAPACITY (i.e. the LOWER the VOLTAGE, the HIGHER the CAPACITY; this is the FIRST time for the majority of the Rayovac 1600mAhs in the C9000 so we'll see how this 'theory' pans out. AGE also plays a part here since I don't expect to see +90% CAPACITY even on those (surprisingly LOW resistance) 1.5_VDC ~7+ year-old cells.).
[Another 'experiment' on my To-Do List is to create a chart comparing the voltage displayed during a C9000 IMPEDANCE CHECK with the measured INTERNAL RESISTANCE using a resistor and a DMM. My 'Round Tuit' seems to have rolled somewhere... :shrug: ]
Compare those numbers above to today's batch of !TRASHED! cells:
Code:
NiMh Rayovac AA 1600ma 1: 04/10/09 - 'HIGH' (Impedance Check C9000) ONV-Y !TRASH!
NiMh Rayovac AA 1600ma 1: 04/10/09 - 2.11VDC (Impedance Check C9000) ONV-Y
NiMh Rayovac AA 1600ma 1: 04/10/09 - *WARM* (Charge PS-3 500) ONN-Y
NiMh Rayovac AA 1600ma 1: 04/10/09 - 'HIGH' (Impedance Check C9000) ONN-Y ?TRASH?
NiMh Rayovac AA 1600ma 1: 04/10/09 - 2.39VDC (Impedance Check C9000) ONN-Y
NiMh Rayovac AA 1600ma 1: 02/18/09 - 1102mAh (Refresh2 BC-900 200) ONN-Y ?Recycle?
NiMh Rayovac AA 1600ma 1: 02/xx/09 - 871mAh (Refresh1 BC-900 200) ONN-Y
NiMh Rayovac AA 1600ma 1: 01/28/09 - 1171mAh (Refresh BC-900 500) ONN-Y
NiMh Rayovac AA 1600ma 1: 01/22/09 - 1088mAh (Refresh BC-900 700) ONN-Y
NiMh Rayovac AA 1600ma A2: 04/10/09 - 'HIGH' (Impedance Check C9000) ONV-Y !TRASH!
NiMh Rayovac AA 1600ma A2: 04/10/09 - 2.43VDC (Impedance Check C9000) ONV-Y
NiMh Rayovac AA 1600ma A2: 04/10/09 - *WARM* (Charge PS-3 500) None
NiMh Rayovac AA 1600ma A2: 04/10/09 - 'MODE' (Impedance Check C9000) None ?TRASH?
NiMh Rayovac AA 1600ma A2: 02/17/09 - 'HIGH' (Break-In C-9000) None ?Recycle?
NiMh Rayovac AA 1600ma A2: 02/17/09 - 1191mAh (Refresh3 BC-900 200) None
NiMh Rayovac AA 1600ma A2: 02/xx/09 - 1175mAh (Refresh2 BC-900 200) None
NiMh Rayovac AA 1600ma A2: 02/xx/09 - 1158mAh (Refresh1 BC-900 200) None
NiMh Rayovac AA 1600ma A2: 02/12/09 - ---mAh (Charge RadioShk140/13) None
NiMh Rayovac AA 1600ma A2: 02/12/09 - ---mAh (Discharge Superman) None
NiMh Rayovac AA 1600ma A2: 02/11/09 - 0mAh (Discharge C-9000 100) None
NiMh Rayovac AA 1600ma A2: 02/11/09 - 'HIGH' (Charge C-9000 800) None
NiMh Rayovac AA 1600ma A2: 01/20/09 - 1265mAh (Refresh BC-900 700) None
NiMh Rayovac AA 1600ma 1: 04/10/09 - 2.45VDC (Impedance Check C9000) ONV-Y
NiMh Rayovac AA 1600ma 1: 04/10/09 - *WARM* (Charge PS-3 500) ONV-Y
NiMh Rayovac AA 1600ma 1: 04/10/09 - 'MODE' (Impedance Check C9000) ONV-Y ?TRASH?
NiMh Rayovac AA 1600ma 1: 02/13/09 - 1085mAh (Refresh2 BC-900 200) ONV-Y ?Recycle?
NiMh Rayovac AA 1600ma 1: 02/12/09 - 585mAh (Refresh1 BC-900 200) ONV-Y
NiMh Rayovac AA 1600ma 1: 01/20/09 - 858mAh (Refresh BC-900 1000) ONV-Y
NiMh Rayovac AA 1600ma 1: 01/20/09 - ----mAh (Charge BC-900 1500) ONV-Y
NiMh Rayovac AA 1600ma 1: 01/18/09 - 648mAh (Refresh BC-900 1000) ONV-Y
NiMh Rayovac AA 1600ma 3: 04/10/09 - 'HIGH' (Impedance Check C9000) ONV-Y !TRASH!
NiMh Rayovac AA 1600ma 3: 04/10/09 - 2.40VDC (Impedance Check C9000) ONV-Y
NiMh Rayovac AA 1600ma 3: 04/10/09 - *WARM* (Charge PS-3 500) ONV-Y
NiMh Rayovac AA 1600ma 3: 04/10/09 - 'MODE' (Impedance Check C9000) ONV-Y ?TRASH?
NiMh Rayovac AA 1600ma 3: 02/11/09 - 1065mAh (Refresh BC-900 200) ONV-Y ?Recycle?
NiMh Rayovac AA 1600ma 3: 02/07/09 - 661mAh (Refresh BC-900 700) ONV-Y
NiMh Rayovac AA 1600ma 3: 02/06/09 - 396mAh (Charge BC-900 1000) ONV-Y
NOTE: This 'overly-wordy' single-line style of Charge Log is a carryover from my Excel spreadsheet where, since the majority of my NEW NiMH cells were Rayovac (1600mAh), I was tracking them by the BATCH IDs printed on them (instead of numbering them from 1-N). For my non-Rayovac cells, I've switched over to the 'Table' format that you'll see in my other posts.
