[ QUOTE ]
Why not using a seperate resistor?
[/ QUOTE ]
I've been using the light with 6 NiMh, and that works fine. I've let it run for over half an hour at a time, several times. It's really bright and delightful. So I don't need a resistor, but I needed one more rechargeable for another light, so I figured I could run the 5 Watt on 5 batteries, and one dummy. But when I started to put it together, I thought, why not just put the alkaline in without converting it to a dummy. Then I thought it was best to check with you guys to see if there's anything to worry about.
Thanks for the tip on how to include a resistor with the battery packs. I was thinking in that direction myself, but your solution is better than what I was thinking of.
I have a Reactor 3 which comes with a 2.4 ohm resistor, and I might like to replace it with something a little smaller.
I like the idea of being able to change resistance depending on what kind of batteries I'm planning to use, and what condition they are in. Thanks again.
