houtex
Copied from Lighthound. Loaned out to me for one night from JohnC.
This flashlight starts life as a respectable MC-E LED flashlight, and is then upgraded with a new converter and an incredibly bright SST-90 LED. This flashlight has been tested at 729 REAL Lumens, and blows away flashlights that are rated at 900 lumens. The 26650 battery provides an incredibly long run time, and the convenience of charging a single battery for 2 full hours of usage on high, over 40 hours on medium, and hundreds of hours on low. The excellent heatsinking provides virtually no fade due to heat and the flashlight can be run for extended periods without overheating.
Specifications
white wall about a foot away
SST-90 on left EagleTac M2XC4 Cool on right. Both on high.
Control(sorta) first,then the ET,and last the SST-90.
I can take pics about as good as I can spell. I don't have any equipment to measure anything but will try to answer any ???? you guys may have.
Not any real throw to it but it is HELLLLA BRIGHT!
Specifications
- LED: SST-90 LED, GN100 tint
- LED Circuit: Direct Dirve
- Load Voltage: 2.8V-4.2V
- Operating Temperature: -25 C - 65 C
- Output - 729 Lumens Measured
- 3 Modes: High (100%) / Mid (60%) / Low (30%)
- Input Runtime: 2 hours with High mode output
- Beam Angle : 20 degrees
- Switch Type: Reverse Click Switch
- Finish Type: Hard Anodized, Type III Anodizing, Skidproof & Scratchproof
- Lens: Toughened Glass
- Reflector: Aliminium with orange peel film plated(37mm) MOP
- Springs: Steel Silver Coated
- Material of body: Aero-Al 6061 T6
- Battery Type: 1* 26650 Li-ion or LiFePO4 Battery Voltage Input: 3.7V-4.2V
- Waterproof: Double O rings sealed front and back, works well under 2 metres of water
- Heat Sink: Ultra-thick copper pill with driver board in it and emittor board contact to Exterior Cooling Fins
- Color: matte black
- Dimensions: 147mm*41mm*32mm
- Net Weight: 230g(without battery)
