mm doen\'t work...might be because of battery fluid
hi guys, been out for quite a while.
my madmax in a minimag is not working. quite a while back i took out the alkalines and found out that they leaked some juice into the barrel. i swabbed the inner barrel with alcohol and swiped it with dry tissues.
i left it at that for a few weeks and yesterday put some fresh batteries in. the mm did not work. i looked into the tail threads and saw some whitish stuff. i picked them out with a pin but some stayed there. i looked into the inner lip of the barrel (where the sandwich gets in contact with) and there are several dark spots under it. i tried to pick them out with a pin but somehow they seem to stay there (they feel flat). the top portion of the sandwich (the shiny portion to contacts the inner lip) looks spotty too so i cleaned them with the pin and some dry tissues.
i reassembled the flashlight (i am using a kroll) but it did not light up. when i pushed or moved the led via the black base using my two nails from either side the led would flicker. sometimes it would stay lighted but most of the time it would die down.
how do you clean the inner barrel and the sandwich to regain the original contact? any other thoughts would be appreciated?
tia. /ubbthreads/images/graemlins/confused.gif
