Mod-A-Mag battery holders fitting inside new M*gs
nicknich22931
Covesville, VA, USA 22931
I have a new 2D Maglite and want to run AA batteries, both rechargeable NiMh, NiCd, and primary alkalines or lithium. I get the impression that some cells might be a tight fit in the 8AA to 2D adapter for the newer M*gs. Is this true? Is the 6AA to 2D adapter any better?
:thanks:
An 8 AA adapter will require a quad bored light. 6 AA should fir a standard mag OK. Look for member Jesus Hernadez to bore the light for you.
Norm
I was under the impression that some of the older mags had slightly larger bores and would accomodate the 8AA to 2D holders???
Yes,thats correct.
Lights with an all numerical serial number will have sufficient room for 8xAA's without modification.
Newer lights whose serial number begins with a letter will most likely,but not always,have to be bored.
-Michael
Yes,thats correct.
-Michael
I check mines 3 D maglites and 4AA fit well, but I dont know about Li-Ion types like 14500
