300winmag
I recently bought a couple pairs of nice projector fog lights, I want to keep one set stock but want to mod the other set into spot lights.
I took one apart and I think all I have to do is remove a cut off shield and put the lens a little further away from the bulb. Or does it work the other way?
At any rate just the way these lights are designed it will be easy putting in a spacer between the two half's of the light or take some material off the light to bring the bulb closer. Just need some info on the know how folks.
Thanx for any help.
Thanx for any help.
