Modified L1, 2X123A(or 1 168S),LuxIII, Aleph1 head
funder
Pittsburgh, PA
I shortened the Ecan for LE and the stand in the tail switch, adjusted the spring to make it more compact when depressed.
The driver is NG 917, TWOJ Lux III
Icarus
Belgium
Very nice mod and great pictures too! /ubbthreads/images/graemlins/clap.gif /ubbthreads/images/graemlins/clap.gif /ubbthreads/images/graemlins/clap.gif /ubbthreads/images/graemlins/happy14.gif
Any chance you'll post a picture of the back of the Aleph1?
It looks like I've seen that delrin tailcap before. /ubbthreads/images/graemlins/thinking.gif
funder
Pittsburgh, PA
You mean the pics of the LE's bottom? I will shot some for you, the Ecan was filed down by hand so it look's not smooth and nice /ubbthreads/images/graemlins/frown.gif
christrose
Japan
Re: Modified L1, 2X123A(or 1 168S),LuxIII, Aleph1
Great mod!
I'm also modifying L1 for PR, but I began to want an A1 head. /ubbthreads/images/graemlins/grin.gif
BTW, isn't NG destroyed by using 2x123A?
Icarus
Belgium
Thanks a lot for posting the pictures! /ubbthreads/images/graemlins/thumbsup.gif
How much did you have to file off the ES-can?
In my opinion the Aleph1 has the perfect size and shape for the L1.
I like the L1 very much and have two of them waiting to be modded.
However they have to wait since I'm too busy doing FatMag's and FlexMags. /ubbthreads/images/graemlins/icon3.gif /ubbthreads/images/graemlins/grin.gif
akula88
BisDak [Area X] ^^.PH
Fang,
Well done!
Turning the L1 to be 2x123 capable is difficult.
I have disassembled and ultimately destroyed an L1 tailcap just to find this out. There's really no more space in there.
Thus...I stopping at the Pila150s level. If I need to go forward, it would be a neck extender. I'm not a fan of a dedicated head, but rather like the idea of using just about any e-series head on the L1 body.
Larger Image
funder
Pittsburgh, PA
christrose, I've seen some guy use NG with 2 123A, but now I just use 168S because it cost lower.
icarus: I am not sure the actural size of the ecan before I file it(I use some tin to add the height of the edge for the Ecan before I file it), file a bit and make a trial match, then repeat. I will meature the dimension of this modded ecan later.
akula88: To make it fit 2 123A size both the head and tail switch have to be modded, we have to fight for every mm.
Icarus
Belgium
/ubbthreads/images/graemlins/wow.gif... Thanks! Which software did you use to make the drawing?
tylerdurden
Roaming Around - Southern USA
Very nice. /ubbthreads/images/graemlins/thumbsup.gif
Is that ecan turned from scratch or did you modify an existing ecan? If you modified one, did you use the LE ecan or the older ecan from the McLux head?
I can't see how you could get the inner lip that close to the upper lip by modifying a standard ecan.
funder
Pittsburgh, PA
I use the LE ecan. Use some tin to enhance the height of the lips and crop into right shape by file.
I will ask a friend of mine to make some of this ecan by machine.
McGizmo
Maui
Nice job funder! /ubbthreads/images/graemlins/thumbsup.gif Did you have to put any relief in the E-Screw for the DB components?
funder
Pittsburgh, PA
McGizmo, sorry I am not clear what do you mean by "reflief", In the above showed LE I shortened the ecan too much so I have to file down the escrew a bit for compensation, AAA filled inside.
Krit
Thailand
Wow cool L1 /ubbthreads/images/graemlins/clap.gif
