old4570
Id like to thank Member : Tohuwabohu for the mod information .
Resistors go @ R13 and R30 depending on the channel you need to mod ..
Now I used a 2M ohm variable resistor , and I used it on the channel that went way over 4.2v on better cells , and Im not sure if I should be using an ever higher ohm resistor .
Im currently testing with the 2M , and the open voltage is right on 4.2v . whilst the other channel which stops right on the money at 4.2v has an open voltage of 4.21/4.22v ..
The first battery stopped at 4.19v , but Im retesting as I type this ..
Method ..
I put the variable 2M ohm resistor in at R13 set for 0 ohm reading which resulted in an open voltage reading of around 1.35v [ maybe ok for Charging AA's ]
Anyhow , as I tweaked the resistance the voltage went up , I think Im fully set to 2M at the moment , with an open voltage of 4.2v [ waiting to see what termination voltage is with the next battery ]
To get a termination voltage of exactly 4.2v [ to match the other channel ] I might need a slightly higher ohm resistor , I'm not sure whats available after 2M , but I will have a look on ebay after this battery is charged . Originally this channel went to 4.23v , Im not sure what the open voltage was ? If its anything like the other channel , it might have been 4.24/4.25v ..
Charger just finished , and the battery is reading 4.19v/4.2v so its not quite holding 4.2v but rather jumping between 4.2v and 4.19v .. So I need a ever slightly higher ohm resistor .
I will update this when I get a new resistor .
Method ..
