This is a follow-up question based on these WF-139 tests:
http://www.candlepowerforums.com/vb/showthread.php?t=209785
http://www.candlepowerforums.com/vb/showthread.php?t=205036
The key assumptions are:
- using quality protected 18650/14500 cells such as from AW
- willing and able to monitor WF-139 charger
(meaning I won't forget to check it and such)
My question is:
Can I simply use a DMM to monitor charge voltage on WF-139 and terminate at 4.1V (happy with 80%-90% SOC) in order to ensure:
- safe charge process, eliminate all risk
- long cell lifespan
In other words, is using a simple DMM to stop charging at 4.1V practical and sufficient assuming I will remember to check? Is a simple DMM good enough? Are there other steps necessary?
thanks
My question is:
thanks
