mouse/computer freeze problem
gollum
Brisbane
my mouse keeps freezing and stops the computer aswell including windows media playback.
mentioned to a mate at work and he said he has a similar problem
so I tried a search and came up with a few supposed solutionsbut they didn't work
I am capable of following walk thru tutorials but thats about as good as it gets for me on this thing
so anyone have the magic solution
is this common at the moment
my computer is fairly new and updated
running a 6 core processor
mozilla and firefox
got spyware and avg and other stuff also
I did the troubleshoot thing and it said working ok
somewhere it said something about flow overload or something like that???
anyhow any help would be great and maybe also help others
sorry
it is wired and I tried another one and had the same result so its not the mouse
I had a computer freezing problem when I built the one I am using. It would freeze for up to 15 seconds at a time and after days of trying to figure it out I traced it down to a bad SATA cable on a dvd burner. It seems windows at times will check drives and when they are not working properly it causes your computer to freeze till it times out.
+1 on the sata cable.
I've also had the same symptoms from a heavily fragmented HDD, or a handful of bad sectors affecting system files.
Get Auslogics Disk Defrag and Crystal DiskInfo to check for either of those.
This is one of those "could be a lot of things" issues that you'll need a geek to sit down for an hour and figure out what it isn't by process of elimination.
thanks guys
i think you are right a man with a spaceinvaders t-shirt is the way to go
but I will check the dvd
6 core system... Sounds like there may be an AMD driver causing bedlam in the graphics department. Try updating the drivers (I have a distinct memory of some AMD drivers being so horrid that my monitor couldn't even stay synced with the graphics card for more then a second)
The first thing you should try is determine if the problem is caused by the OS or not. Boot it with a live CD and see if it hangs.
check for error messages in windows event viewer
and as posted above, if you have a bootable cd or flash, boot that, load a mouse driver, play around try to recreate the problem
ok first ...
thanks to everyone who is trying to help out here I appreciate it guys
Moddoo.. I am running windows xp (is that what you meant, sorry I don't know more)
H-man, thanks I will try to find something in the tutorials
Too many gizmos ... I did that,went thru the troubleshoot proceedure ,still happening.
vali and 127... I will try to do these things also
I suppose it just takes time as I am a bit lost when it comes to tech stuff,
I'll use google search + tutorials and see what happens
I can always do a system restore
I was hoping a magic tweak could fix it but at least I can try a few things
Thanks guys
I will let you know if I fix it
if you are running Windows XP 64 bit, Flash player is not supporting that OS anymore.
it's giving me trouble on one of my machines too.
Only while streaming video. Youtube use is when most of the freezes happen.
thanks Moddoo
not sure but yes the video streaming is not working unless I keep moving the mouse
I've had a go at a few things tonight but i will try more tomorrow
cheers Jason
gollum, you here right now ?
check your PM I can do a quick webex to your box and give it a look
but this is only for short time period
Barring a hardware problem, in my experience these are driver issues. When was your last mouse driver update? Same for video, security...
Zone Alarm (free) and Nvidia drivers bring me the most problems.
