MR15 which features In long running time(Max 9.5 days), 1200lm light out, powered by 1*21700(5000mAh Li-on battery).
It owns a hidden Micro-USB rechargeable port and 4 power indication lamps which shows you the battery’s volume, the raising button is for Strobe function.
It’s compatible with 5 sorts batteries,1*21700/1*20700/1*18650/2*CR123A/3*AAA(need an adapter Included).
Here is the features:
* High-strength aerospace aluminum body
* Mil-Spec hard anodized for extreme durability
* Resists impact PMMA while providing high light transmittance levels
* Metal filmed reflector to create a high intensity beam
* Waterproof O-Ring seals
* Maximum output of 1,200 Lumens and 245-meter beam distance
* Side switch controls 4 illumination levels (Turbo, High, Medium, & Low) and Strobe mode.
* Mode Memory
* Hidden Micro USB port for recharging
* Four flush mounted LEDs to indicate charging status and battery level
* Compatible with 5 different battery configurations
* IPX-8 water resistance
* 2-meter impact resistance tested
* Mode Memory
