Never thought my first post on cpf would be on this section...
So 2 or 3 weeks ago I ordered 2 cheap unprotected 18650 on eBay, today they finally arrived, first thing I did was check the voltages.
Both were around 3.5v, great, let's charge them, so I put them on the charger, and since they were unprotected, I was being careful and measured the voltage every 30-45 minutes and checked if either the batteries or the charger were getting hot, nope, all fine.
------ Here ends the "being very careful, safety first" part of this post -----
Meanwhile they finished charging and being an "inventive" guy, just for fun, I decide to convert a crappy 3xAAA flashlight to 1x18650 <--- First signs of a Bad Idea!
So I measure the "victim" (flashlight), inside diameter ~23mm, depth ~68mm, good, a 18650 will fit without problem, a bit of paper to fill the diameter and it's done.
So without much more planning or modifying I stick the battery in there and start screwing the tailcap, suddenly the light turns on - it scared me, but I clicked the switch and it turned off, good, thought it had short circuited, but no, at least not for now - so I finish screwing the tailcap, click the switch and a nice light starts shining (as nice as possible on a cheap, 5mm LED flashlight), nice, let's turn it off and put the 18650 in my battery storage box.
*click* "Hmmm, doesn't turn off" *click* "Oh, *censored*, short circuit."
I unscrew the tailcap as fast as I can, remove the battery and as I remove it I see a bit of smoke coming from inside the flashlight (all of this in ~5 seconds), I go outside as fast as I can and put the battery on the concrete floor, and stay a few meters away looking at it for a few seconds.
-------- Here ends the "Oh, *censored*" part of this post -----
Good, no damage.
So, what the heck went wrong?
I start looking at the inside of flashlight and notice the spring on the positive side, instead of being pointy side to the battery, flat side to the led circuit, it was flat side to the battery pointy side to the circuit.
I guess that, when I was screwing the tailcap I was putting too much pressure on the battery (didn't measure depth correctly), which was putting too much pressure on the spring, which caused the spring to spread or slide with enough strength to get under the protective plastic on the top of the battery and cause a short, another problem is that I didn't make sure the battery was tight enough on the sides, it could still move a bit.
Of course, all this text and no pics isn't acceptable (bad quality pics, but pics, be happy with that )
The spring that (probably) caused it all:
The poor battery:
So while this was quite a stupid error, I feel even more stupid because I was being as careful as possible until then.
No fire, no explosion, no damage, no nothing, only one (probably) dead battery and a bit of smoke, the battery didn't even get warm, impressive I would say, still, I better not keep pushing my luck and stop shoving 18650 into slightly modified 3xAAA flashlights.
In the end, my first day with Li-Ions, could have been worse.
*edit*
Some updated info in post #7
Good, no damage.
The poor battery:
*edit*
