Hello there..
I've been wanting to make an LED lamp for my desk for some time now. A few days ago I saw this Lamp and that's very similar to what I want. After reading up on it and I have some understanding on the basics about LED voltage, current, and resistors. But I am still unclear about the power supply and what I need to have so I can just plug it into the wall.
My plan is to use a aluminum C-channel to mount the LEDs in twos and staggered them. I want about 140 LEDs, 2 in series and then 70 pairs in parallel.
THE SPECS from http://led.linear1.org/led.wiz
Today I read about bridge rectifiers and capacitors to smooth out the flickering of LEDs on AC power. Would I also need this?
Well anyways I am sure there are many ways to power this lamp, but what would be the most stable and easiest and cheapest solution to power this lamp?
Thanks a lot for the help.
Jason
- each 330 ohm resistor dissipates 132 mW
- the wizard says the color code for 330 is orange orange brown
- the wizard thinks 1/4W resistors are fine for your application
- together, all resistors dissipate 9240 mW
- together, the diodes dissipate 8960 mW
- total power dissipated by the array is 18200 mW
- the array draws current of 1400 mA from the source.
Jason
