First I would like to thank everyone here. There is no way I could have done this without you all and this great resource/website.
This thread helped me out immensely: http://www.candlepowerforums.com/vb/showthread.php?t=85713
Here is my parts list:
Mag 2C host
3x SSC P4 stars
3x IMS 20mm reflectors
shark driver
PTS2 tri-sink
Deans micro plugs
UCL glass
24awg wire
2x AW's protected 18650's
Arctic Alumina
I will be switching to modamag's clicky tail cap as soon as I get a cut-down mag c body and a couple of AW's C li-ions. It looks like I'll be needing around a 127mm tube. I have been hitting up TAP plastics and am still playing with ways to get a positive contact to get rid of the stock switch.
Here's some pics:
I drilled a hole in the ecan end of the PTS2. I'll use this as my negative path as soon as I switch to a tail cap.
Here is my crappy soldering job.
Here is my messy potting job on the shark driver. I used some Dean's micro plugs to connect the shark to the modified stock switch.
Here is the finished product. I ended up having to remove the retaining ring that holds the stock switch in. Even though I had the micro plugs installed, it made it a lot easier to get the whole assembly back into the body without the ring.
I was scared out of my mind the first time I flipped the switch. Whew!!! Works great!!! This thing is super bright!
Here are some of my earlier threads on this project:
http://www.candlepowerforums.com/vb/showthread.php?t=160050
http://www.candlepowerforums.com/vb/showthread.php?t=160987
I'll post more when I get rid of the stock switch, get a cut-down mag body, and move to the tail clicky.
Mag 2C host
3x SSC P4 stars
shark driver
PTS2 tri-sink
Deans micro plugs
UCL glass
24awg wire
Arctic Alumina
Here's some pics:
