Hi
So I have two 3D maglites at home, one with a std bulb and the other with a Terralux 2/3D dropin.
I have ordered...
1 *MCE (DX)
3 * Q5 WC tint
Some Thermal Epoxy
GITD Power (Just for fun)
But am stuck on driver considerations.
My power requirements for this is one of...
2.7V (3 * depleted NiMH) to Alkaline unloaded voltage of 4.5v I do not know about how sag affects the voltage under load. The options I have are...
3 D size Duracells (Since I have the old unused cells to use up)
3 8000mAh LSD Cells from Maplins (UK store)
3*AA to D parallel using Lithium primaries when I am stuck in a pinch or using some high cap NiMH's instead. Figure that 3*AA is much better and easier to use for my other AA Q5 EDC if I want to use up the cells. Also since 4 LSD's come in a few bob cheaper and can be used in my daughter's electronic toys around the house, I can at least justify the expense to her indoors.
I was looking originally at the AMC 7135 chips in parallel however I have not found a guide here on how to assemble them and if the voltages I am trying to work with would be suitable. For the most part, I figured NiMH with a resistor would be good enough since a 2A load should bring the voltage down close to Vf of the MCE and the flattish discharge characteristics of the NiMH would allow me to have a relatively flat output.
Whilst I am running a Li-ion on my EDC, I would like to avoid this since the other torch may be used by my wife, or if I can get the parts together quickly enough and assembled they will be sent along with my family members onto their trip to India (Thread asking for ones to take advice is here...
http://www.candlepowerforums.com/vb/showthread.php?t=241743
Whilst it would be nice to have a fully regulated driver, I have not been able to read or absorb enough information to be able to make the choices I need on my own.
As for the uses of each torch, one will be lying in a car to be used on the odd occassion however the other will be getting a lot of use.
If you guys can give me any pointers on threads to read or your own experiences with what I have, I would be most grateful.
I have no qualms about reading up some guides or even giving me the search terms to search for in the CPF Google search, just that I have tried some terms I thought my be appropriate and they have bought up stuff which is a little over my head when the stuff gets interesting.
Thanks in advance everyone.
I have ordered...
1 *MCE (DX)
3 * Q5 WC tint
Some Thermal Epoxy
