Today I received a McLuxIII PD HA Nat, courtesy of CPF member fnmag. Wow, what a light, this really is a piece of art! It has a glow ring, titan bezel and trit in the piston.
I have a few questions, I'm hoping someone can answer for me...
1) I don't know why but I thought there would be more travel in the piston. The travel can only be measured in millimeters, but I'm sure this is normal and I just had a false impression in my head? When the piston is depressed, is the light still waterproof?
2) The o-ring on the piston looks a bit worn out and I want to lube it with the right stuff. Some people mention plumber's grease. They sell this at a local home depot http://www.rectorseal.com/index.php?site_id=1&product_id=227 but I'm not sure if will work. Its a red o-ring if that matters.
3) What is the expected runtime on low? I've found many details for runtime on high (1 1/2 hours?) but nothing for low.
4) It seems this light and the HDS lights use the same screws. Where would I find a tool to fit this type screw?
Anything else a new McGizmo owner should be aware of?
Thanks!
WTH
Thanks!
WTH
