Matt7337
Afternoon all, I just have a quick story and question about one of my RCR123 cells. When I first got into flashlights a couple of years ago, I bought my supply of rechargeable cells for the lights that I had and the ones I intended on getting. That was a total of 6 cells - 3x RCR123's and 3x 18650's from AW. A while ago one of those 123 cells stopped working. At first I thought it was the flashlight that had gone
but I put a new primary cell in it that day and it worked fine.
The RCR123 wouldn't take a charge after that, and wasn't reading any output voltage either. So I shelved it for ages - it sat in one of my battery caddies for well over a year. I found it whilst I was clearing out my battery drawer the other day, and decided for the sake of interest to take the black wrapper off it and have a look at the protection circuit. When I had it stripped back, I put a voltmeter on the actual terminals of the cell - bypassing the protection circuit - and it read 2.8 volts. Remember that this was the cell that read zero volts on my multimeter using the outer terminals before.
So, I decided to chance it and removed the protection circuit from it along with the small connecting strip for the +ve contact, and put it in my Ultrafire WF-139 charger with an aluminium spacer to make it up to 18650 size. It began charging immediately, so I turned it off and put a DMM on it to monitor the voltage through the charging cycle. It charged all the way up to 4.25 volts, at which point the charger stopped, as expected.
I have it in my Nitecore Extreme now and it's working perfectly. My question is this - I know the WF-139 charger protects cells from over charging but which (if any) of my CR123 sized flashlights (see sig) will protect this cell from over discharging below 3V?
I know some of you may not exactly be thrilled at hearing that I pulled the protection circuit out of a protected cell, but I only have 3 of them and I really needed this one working - the protection circuit was obviously faulty and I didn't damage the actual cell in any way, and I closely monitored the charge cycle of the unprotected 123. I really need to buy some more AW cells now though. I have way more lights now than I had when I bought the 6 AW's that I have
Thanks in advance for any help or advice.
