Celest
So in my previous thread discussed my very first LED light, so I thought that maybe I should share my entire collection which is quite interesting to say the least. So at the top is my first LED light, lantern style, which you can see more about in my previous thread. The second one is my 60 lumen $5 2AA Rayovac LED light, one of my daily drivers. The third is another cheap metal cased Rayovac, which has a laser pointer. Sadly this one hasn't seen much use due to the switch not having lasted very long before degrading pretty badly (if anyone knows how to take that thing apart and fix the switch, PLEASE tell me as I otherwise love that thing). Below that is a 2 lumen Rayovac penlight (was only 3 bucks so couldn't resist). The fifth is a cheap checkout lane EveryReady 100 lumen which is nice and works OK but the switch despite not breaking feels like excessive use could wear it out so I only use it from time to time so that it lasts me longer. The sixth thing is pretty interesting. So Walmart sells these Promier/LitezOn "wireless light switch" thingies. They don't have a resistor in series (with the exception of one unit I tore down at one point) so if you put anything better than the included zinc-carbon batteries, it will cook itself and is a potential fire hazard. I added a USB cable ran it at with a cooling fan since any decent USB power source will make it draw a staggering 13 watts. The reason it has too much hot glue on it is from repairs due to heat damage of the case from the few times I forgot to turn the fan out. It is currently decomissioned. Below is another better quality wireless light switch thingy that has a current-limiting resistor but said resistor gets hot (evident from the burn mark on the back) and I have a pair of spares just in case. Lastly, on the bottom is my favorite and main daily driver, the 200 lumen Tzumi Alpha Pocket Charger 2000mAh. It was just $9.88 at Walmart and I both needed and wanted a half decent high power light for cheap. Judging by the shape it projects on the wall, I think it is some kind of lower end Cree XM-L series LED of some kind (or a very good clone). It can shine on building sides from a distance, etc... Pretty fun to play with both indoors or at night outdoors (a faint but noticeable projection of the LED is visible on trees on the other side of my campus football field, and can very clearly project onto the side of the main campus building while I am standing in the nearby garden grass. For short range stuff it is way more bright than I would ever need and can dimly light up a near pitch black section of the campus golf course. pretty amazing for only 200 lumens and something sold in the phone accessory section at Walmart. The USB output is 1A and useless for modern cell phones, but you can plug in a USB lamp or two and get more juicy lumens from it...
Photo:
free picture hosting
Photo:
