J!m
So I'm at work, using my G2 to check plasma gun bores, and a customer I'm working with asks to see my light to check the bore himself.
I go off to do another task, and he comes back five seconds later, and says: "OK, what's the trick?" He couldn't get it to light up, and neither could I.
The batteries are the original set on a 120L SureFire drop-in, so I don't think it was overdriven. It may have flashed, but I think we would have noticed that... I just used it less than five minutes prior to handing the light over (it wasn't even dropped in between), and it was working just fine.
Anyway, I will check the voltage in the cells now, but is there anything else I might be missing, besides the obvious filament failure? If the batteries outlast the bulb, I will be a bit miffed...:thumbsdow
